StarTech.com 3-Port IEEE-1394 Notebook Firewire Card
Customer rating: 4.0* (Write a review)
Quicklinx: 2QFHWS00 Mfr#: CB1394
This 3 Port PCMCIA IEEE 1394 FireWire 400 Laptop Adapter Card allows you to connect FireWire/i.LINK devices such as iPods or DV (digital video) camcorders to your laptop computer through a CardBus slot.
Compatible with both PC and Mac laptop computers, the adapter card supports hot-swapping FireWire device connections, allowing you to unplug and swap peripherals with ease.
The adapter card includes a 5ft FireWire cable as well as a copy of ULEAD's VideoStudio SE Basic video editing software, making it easy to capture and edit video on your notebook computer, directly from your digital video camcorder.
StarTech.com 3 Port CardBus 1394a FireWire Adapter Card - Digital Video Editing Kit - FireWire adapter - CardBus - FireWire x 3
FireWire adapter
Plug-in card
Interface (Bus) Type
CardBus
Ports
FireWire x 3
8.6 cm x 5.4 cm x 0.5 cm
0.2 kg
Firewire
Data Transfer Rate
400 Mbps
Microsoft Windows 98 Second Edition, Microsoft Windows 2000, Microsoft Windows Millennium Edition, Microsoft Windows XP
P/N: CB2EC
FireWire adapter
Plug-in card
CardBus
Ports
FireWire x 3
Wired
IEEE 1394 (FireWire)
Data Transfer Rate
400 Mbps
3 x FireWire - 6 PIN FireWire - male - 3
Compatible Slots
1 x CardBus
1 x IEEE 1394 cable (external) - 1.8 m
Plug and Play
Software Included
Drivers & Utilities, Ulead VideoStudio SE
8.6 cm
5.4 cm
0.5 cm
0.2 kg
Limited warranty - parts and labour - lifetime
P/N: CB2EC
Customer reviews
Write a review for the StarTech.com 3-Port IEEE-1394 Notebook Firewire Card here!
do noy buy for use with ipod
Reviewed by . Review Posted 17/06/2004
I bought this with a view to using it with my Ipod. I soon discovered by mailing techsupport that it is not designed for this.
So i have a card which is useless to me. Do not buy thinking you can use this for charging and syncing an ipod because it is a firewire card of sorts.
  • Overall 5*
  • Ease of use 3*
  • Value for money 1*
Reviewed by Anonymous Review Posted 29/06/2004
This card looks the ticket with 3 ports and a great price and editing software etc, etc....but it actually damaged hundreds of avi files on my external firewire/usb drive. I am returning it for a more expencive make in the hope that a more relaible make will work better. Buyers Beware!!!
  • Overall 3*
  • Ease of use 3*
  • Value for money 3*
The opinions expressed in this reviews section are those of our customers and not of BT Business Direct. Nothing contained herein amends BT Business Direct’s terms and conditions.
