StarTech.com 3-Port HDBaseT Extender Kit
Quicklinx: CKQGWS00 Mfr#: ST124HDBT
Hurry, only 2 left in stock!
£797.63 ex VAT
£957.15 inc VAT
Distribute your HDMI source to three remote displays over standard CAT5, CAT6 or CAT7 cable. This 3-Port HDBaseT extender kit lets you extend an HDMI source to three remote locations, using HDBaseT technology. The kit includes three remote receiver units, and the transmitter features a local HDMI output, which gives you the ability to keep a fourth HDMI display at your local video source.
This all-in-one extender kit saves you the complications and compatibility issues that can happen if you're not using the correct receivers. It's perfect for use in corporate environments such as small or large offices, or in retail, hospitality, and educational establishments.
With the A/V industry adopting 4K as its new high-resolution standard, long-range video distribution can be difficult, especially considering the 4K distance limitations on standard HDMI cables. You'll be amazed at how this HDBase-T extender kit can deliver your video signal to three different locations while maintaining 4K Ultra HD picture quality. You get four times the resolution of high-definition 1080p, even at 130 feet away from your video source.
The extender is also backward compatible with 1080p at 230 feet, so you can comfortably use it to make any video source look great.
HDBaseT technology offers a single-cable installation, so you can integrate this solution seamlessly using your existing CAT5e or CAT6 infrastructure. Plus, each device included with the HDBaseT extender kit is mountable, so you can keep the equipment out of sight in an equipment rack, or on a wall. This helps to reduce clutter and ensure a professional installation that doesn't draw your viewers' attention away from the content on your display. It's perfect for customer-facing displays in bars or restaurants.
HDBaseT is a standardized, zero-latency video technology that's revolutionizing HDMI distribution. HDBaseT uses an advanced method of modulation that enables you to distribute uncompressed HDMI audio and video, along with additional signals, over a single Ethernet cable.
Offering greater versatility than traditional HDMI extenders, and longer distances than HDMI cables alone, HDBaseT is the clear choice for every integrator and system designer. It can do so much, with just a single cable.
  • A complete extender kit that includes transmitter and receivers
  • Astonishing 4K picture quality from an impressive distance
    With the A/V industry adopting 4K as its new high-resolution standard, long-range video distribution can be difficult, especially considering the 4K distance limitations on standard HDMI cables. You'll be amazed at how this HDBase-T extender kit can deliver your video signal to three different locations while maintaining 4K Ultra HD picture quality. You get four times the resolution of high-definition 1080p, even at 130 feet away from your video source. The extender is also backward compatible with 1080p at 230 feet, so you can comfortably use it to make any video source look great.
StarTech.com 3 Way HDMI Splitter - HDBaseT Extender Kit w/ 3 Receivers - 1x3 HDMI over CAT5e / CAT6 Splitter - 3 Port HDBaseT HDMI Extender - Up to 4K (ST124HDBT) - video/audio extender
Video/audio extender
Rack-mountable
Max Transfer Distance
70 m
AC 120/230 V
26.2 cm x 28.9 cm x 7 cm
1.6 kg
Rack-mountable
Wired
Max Resolution
4096 x 2160 @ 30 Hz
70 m
4K resolution support, Dolby TrueHD support, DTS-HD support
3 x HDMI - 19 pin HDMI Type A female , 1 x IrDA - mini jack
4 x IR transmitters, 4 x IR receivers, 3 x HDBaseT receivers
FCC, RoHS
External power adapter
AC 120/230 V
26.2 cm
28.9 cm
7 cm
1.6 kg
0 - 80% (non-condensing)
CKQG StarTech.com HDMI Over CAT5/CAT6 Extender with Power Over Cable - 165 ft (50m) In Stock £90.68
CKQG StarTech.com Lockable Floor Stand for iPad In Stock £134.45
CKQG StarTech.com 3-Port HDBaseT Extender Kit In Stock £797.63
Price Range Ex VAT: £750 - £1000
