3-Port MST Hub, DisplayPort to Triple HDMI Monitors, 4K 60Hz, DP 1.4 Multi-Monitor Video Adapter with 1ft (30cm) Built-in Cable, USB Powered, Windows Only - Multi-Stream Transport Hub (MST14DP123HD).
Drive triple 4K 60 Hz displays with HDR
Multi-Stream Transport (MST) technology combines multiple video signals into a single output signal/stream. This MST Hub separates the single input stream into three independent signals, one for each HDMI-enabled display. Support for High Dynamic Range (HDR) facilitates enhanced contrast, brightness, color, and luminosity. -
Multitasking made easy
Configure the triple-HDMI displays in extended or mirrored mode. Create a high-performance workstation by adding three independent 4K 60 Hz displays. This empowers increased multi-tasking across your organization, resulting in increased productivity. -
Driverless for rapid deployment and seamless user setup experience
This MST Hub achieves maximum performance with Windows desktops featuring Intel 12th generation (and later) processors, or dedicated graphics cards with DisplayPort 1.4 output ports and DSC support. Plug-and-play installation with no drivers or software required. The 12in (30cm) built-in DisplayPort cable provides options for flexible installation configurations, reducing the amount of strain on the port and connector. Additionally, this triple-monitor splitter is USB Powered and includes a 20inch (50cm) USB Micro-B power cable.
- StarTech.com 3-Port MST Hub, DisplayPort to Triple HDMI Monitors, 4K 60Hz, DP 1.4 Multi-Monitor Video Adapter with 1ft (30cm) Built-in Cable, USB Powered, Windows Only - Multi-Stream Transport Hub (MST14DP123HD) - video/audio switch - 3 ports
- Video/audio switch - 3 ports
- Subtype
- HDMI
- Ports
- 3 x HDMI
- USB powered, plastic housing, 7.1 channel audio support, MST support, HDR support, triple display support, Synaptics VMM5310 chipset, DSC, IT6563FN chipset, wide screen supported
- HDCP 2.2
- 4.3 cm x 10.5 cm x 1.4 cm
- Space grey
- System Requirements
- Microsoft Windows 10 / 11
- 3-year warranty
- Enclosure Type
- Desktop
- Subtype
- HDMI
- Ports
- 3 x HDMI
- Max Resolution
- 4096 x 2160 @ 60 Hz
- HDCP 2.2
- 3 x HDMI output , 1 x DisplayPort input , 1 x micro-USB (power only)
- Space grey
- Cables Included
- 1 x DisplayPort cable - 30 cm
- DOC, RoHS, WEEE, REACH, DisplayPort 1.2, DisplayPort 1.4, DSC, High Bit Rate 3 (HBR3)
- OS Required
- 4.3 cm
- 10.5 cm
- 1.4 cm
- Shipping Width
- 14.2 cm
- Shipping Depth
- 17 cm
- Shipping Height
- 3 cm
- Shipping Weight
- 115 g
- Limited warranty - 3 years , Technical support - assistance - lifetime
- 0 °C
- 40 °C
- 0 - 95% RH (non-condensing)
- Min Storage Temperature
- -40 °C
- Max Storage Temperature
- 70 °C
StarTech.com 3ft (1m) HDMI 2.1 Cable 8K - Certified Ultra High Speed HDMI | In Stock | £15.88 |
StarTech.com 6ft (2m) HDMI 2.1 Cable 8K - Certified Ultra High Speed HDMI | In Stock | £20.72 |
StarTech.com 10ft Ultra High Speed HDMI 2.1 | In Stock | £23.82 |
