StarTech.com 3 Port 2b 1a PCI 1394b FireWire Adapter Card with DV Editing Kit
Customer rating: 4.0* (Write a review)
Quicklinx: 3ZQXWS00 Mfr#: PCI1394B_3
  • Windows 8 (32/64 bits)
Add 2 FireWire-800 and 1 FireWire-400 to your desktop computer through a PCI slot. The PCI1394B 3 3-Port PCI FireWire Adapter Card turns a PCI slot into 2 FireWire 800 (IEEE 1394b) ports and 1 FireWire 400 (IEEE 1394a) port - a cost-effective solution that lets you connect FireWire 800 devices, as well as older FireWire 400 devices to your desktop computer.
A versatile FireWire solution, the adapter card works in both 5v and 3.3v PCI slots and in 64-bit and 32-bit operating environments, making it easy to create a high-speed laptop digital media center, or connect demanding FireWire peripheral devices such as portable hard drives, DV camcorders, digital cameras and CD-RW/DVD-RW drives.
This high quality adapter card is designed to provide reliable FireWire 800 and FireWire 400 connections, delivering 800 Mbps and 400 Mbps data transfer rates respectively (a 64-bit PCI slot is required to achieve 800 Mbps data transfer rates).
StarTech.com 3 Port 2b 1a PCI 1394b High-quality FireWire Adapter Card (PCI1394B_3) - FireWire adapter - PCI 64 - 3 ports
FireWire adapter
Plug-in card
Interface (Bus) Type
PCI 64
Ports Qty
3 ports
Firewire, FireWire 800
Data Transfer Rate
800 Mbps
Linux, Microsoft Windows 2000, Apple MacOS X 10.2.x, Microsoft Windows Vista (32/64 bits), Microsoft Windows 7 (32/64 bits), Microsoft Windows XP (32/64 bits), Windows 8 (32/64 bits), Windows 10 (32/64 bits)
FireWire adapter - 3 ports
Plug-in card
PCI 64
Wired
IEEE 1394 (FireWire), IEEE 1394b (FireWire 800)
Data Transfer Rate
800 Mbps
2 x FireWire 800 - 9 pin FireWire 800 , 1 x FireWire - 6 PIN FireWire
Compatible Slots
1 x PCI 64
Additional Requirements
PCI slot
3ZQX StarTech.com 3 Port 2b 1a Low Profile 1394 PCI Express FireWire Card Adapter In Stock £47.64
3ZQX StarTech.com 3 Port 2b 1a 1394 Mini PCI Express FireWire Card Adapter In Stock £26.08
3ZQX StarTech.com 10 ft 1394b Firewire 800 Cable 9-9 M/M In Stock £11.47
Customer reviews
Write a review for the StarTech.com 3 Port 2b 1a PCI 1394b FireWire Adapter Card with DV Editing Kit here!
More Accurate description
Reviewed by Anonymous Review Posted 29/11/2006
This is a PCI 64 card & some notes from the Instruction Manual, for consideration before purchase.
'A 64-bit PCI slot is REQUIRED for a 800 Mbits/sec. data transfer rate.'
'If you are using the PCI1394b card in a 32-bit slot, make sure that the exposed end of the card is not in contact with any conducting parts on your motherboard. Not all motherboards allow 64-bit cards to fit into 32-bit slots.'
  • Overall 4*
  • Ease of use 4*
  • Value for money 3*
Further comment on 1394b card
Fitting the card into a 32-bit slot was easy, even if it meant adjusting another card to be clear of any contact points on m'board. Driver install was easy but this missed the point, as the whole purpose was to get 800 Mbits/sec or Firewire800 transfer speed! So still at Firewire400 with my 32-bit PCI slots! If only this had been clearer... To connect my Firewire800 device, purchasing 9pin-6pin cable: quicklinx: 4026WS mfr#: 1394_96_10 £12.81 inc vat would be the better choice!
  • Overall 4*
  • Ease of use 4*
The opinions expressed in this reviews section are those of our customers and not of BT Business Direct. Nothing contained herein amends BT Business Direct’s terms and conditions.
