StarTech.com 3 Port 2b 1a Low Profile 1394 PCI Express FireWire Card Adapter
Quicklinx: 6MVSWS00 Mfr#: PEX1394B3LP
Type: FireWire adapter
Compatibility: Mac, PC
Interface: PCI Express x1
£48.82 ex VAT
£58.58 inc VAT
Add 2 FireWire800 and 1 FireWire400 port to any desktop with a PCI slot. This 3 port PCI IEEE 1394a/b FireWire adapter card turns a PCI slot into two FireWire 800 (IEEE 1394b) ports and one FireWire 400 (IEEE 1394a) port - a cost-effective solution that lets you connect FireWire 800 devices as well as older FireWire 400 devices to your desktop computer.
A versatile FireWire solution, the adapter card works in both 5v and 3.3v PCI slots and in 64-bit and 32-bit environments, making it easy to create a high-speed laptop digital media center, or connect demanding FireWire peripheral devices such as portable hard drives, DV camcorders, digital cameras and CD-RW/DVD-RW drives. This high quality adapter card is designed to provide reliable FireWire 800 and FireWire 400 connections.
StarTech.com 3 Port 2b 1a Low Profile 1394 PCI Express FireWire Card Adapter - FireWire adapter - PCIe - 2 ports
FireWire adapter
Plug-in card - low profile
Interface (Bus) Type
PCI Express x1
12 cm x 9 cm x 1.8 cm
46 g
Ports Qty
2 ports
Auxiliary Ports
1 x IEEE 1394 (FireWire)
FireWire 800
Data Transfer Rate
800 Mbps
Microsoft Windows Server 2003, Microsoft Windows Server 2008 R2, Microsoft Windows Server 2012, Microsoft Windows Server 2016, Microsoft Windows 2000/XP/Vista/7/8/8.1/10, Microsoft Windows Server 2019, Apple MacOS X 10.6 - 10.15, Apple macOS 11.0, Apple macOS 12.0, Microsoft Windows 11, Linux 3.5.x or later LTS versions only, Apple macOS 13.0
FireWire adapter - 2 ports
PCI Express x1
Wired
IEEE 1394b (FireWire 800)
Auxiliary Ports
Data Transfer Rate
800 Mbps
2 x FireWire 800 - 9 pin FireWire 800 , 1 x FireWire - 6 PIN FireWire
Compatible Slots
1 x PCI Express x1
FCC, RoHS
12 cm
9 cm
1.8 cm
46 g
Limited warranty - lifetime
70 °C
0 - 90%
6MVS StarTech.com 3 Port 2b 1a 1394 PCI Express FireWire Card Adapter In Stock £49.12
6MVS StarTech.com 3 Port 2b 1a Low Profile 1394 PCI Express FireWire Card Adapter In Stock £48.82
6MVS StarTech.com 3 Port 2b 1a 1394 Mini PCI Express FireWire Card Adapter In Stock £25.55
Compatibility: Mac
Compatibility: PC
