StarTech.com 3 Port 2b 1a 1394 PCI Express FireWire Card Adapter
Quicklinx: 4YLPWS00 Mfr#: PEX1394B3
Type: FireWire adapter
Compatibility: PC, Mac
Interface: PCI Express x1
11 In Stock
£47.93 ex VAT
£57.51 inc VAT
Add 2 native FireWire 800 ports to your computer through a PCI Express expansion slot. This 3 Port PCI Express FireWire adapter card can be installed in a PCI Express slot to add two IEEE1394b (FireWire 800 - 9 pin) ports and one IEEE1394a (FireWire 400 - 6 pin) port, providing broad compatibility with a wide range of FireWire devices (e.g. DV camcorders, external hard drives, digital cameras, etc.).
The 2b, 1a card features a native (single chip) PCI Express chipset - resulting in faster, more reliable and cost effective performance than expansion cards that utilize a "bridge" chip.
  • Efficient data transfer
    With a maximum data transfer rate of 800 Mbps, this FireWire card adapter ensures quick data exchange between connected devices.
  • Versatile connectivity options
    Equipped with two IEEE 1394b ports and one IEEE 1394 port, this adapter allows for multiple device connections.
  • Mac compatibility
    This FireWire card adapter is designed for compatibility with Mac systems, suitable for users with Apple devices.
  • Flexible cable length
    The included external 1.5 m IEEE 1394b cable provides ample length for placement of connected devices in your workspace.
  • Reliable compliance standards
    The card meets UL and FCC compliance, ensuring adherence to recognized safety and performance standards.
StarTech.com 3 Port 2b 1a 1394 PCI Express FireWire Card Adapter - 1394 FW PCIe FireWire 800 / 400 Card (PEX1394B3) - FireWire adapter - PCIe - 2 ports
FireWire adapter
Plug-in card
Interface (Bus) Type
PCI Express x1
Bus Voltage
3.3 V
1.8 cm x 8.5 cm x 12 cm
48 g
Ports Qty
2 ports
Auxiliary Ports
1 x IEEE 1394 (FireWire)
FireWire 800
Data Transfer Rate
800 Mbps
Microsoft Windows Server 2003, Microsoft Windows Server 2008 R2, Microsoft Windows Server 2012, Microsoft Windows Server 2016, Microsoft Windows 2000/XP/Vista/7/8/8.1/10, Microsoft Windows Server 2019, Apple MacOS X 10.6 - 10.15, Apple macOS 11.0, Apple macOS 12.0, Microsoft Windows 11, Linux 3.5.x or later LTS versions only, Apple macOS 13.0
P/N: BNDTB10GI, BNDTB1394B3, BNDTB210GSFP, BNDTB310GNDP, BNDTB410GSFP, BNDTB4M2E1, BNDTBUSB3142, TB31PCIEX16
FireWire adapter - 2 ports
Plug-in card
PCI Express x1
Bus Voltage
3.3 V
Wired
IEEE 1394b (FireWire 800)
Auxiliary Ports
Data Transfer Rate
800 Mbps
2 x FireWire 800 - 9 pin FireWire 800 , 1 x FireWire - 6 PIN FireWire
Compatible Slots
1 x PCI Express x1
1 x IEEE 1394b cable (external) - 1.5 m
UL, FCC
Software Included
Drivers & Utilities
1.8 cm
8.5 cm
12 cm
48 g
Limited warranty - lifetime
4YLP StarTech.com 3 Port 2b 1a Low Profile 1394 PCI Express FireWire Card Adapter In Stock £47.64
4YLP StarTech.com 3 Port 2b 1a 1394 Mini PCI Express FireWire Card Adapter In Stock £26.08
4YLP StarTech.com 10 ft 1394b Firewire 800 Cable 9-9 M/M In Stock £11.47
Resources
The following resources are available for the StarTech.com 3 Port 2b 1a 1394 PCI Express FireWire Card Adapter
Compatibility: PC
Compatibility: Mac
