Power your 5V DC devices from your computer through a USB port. Tired of having to carry around a separate wall adapter in order to power or charge your 5V devices, such as certain external hard drives, streaming media players, and Bluetooth speakers?
This USB power cable makes it easier to power 5V DC devices that have a Type M barrel power connector. You can power or charge the devices through an available USB port on your laptop or desktop computer. Expertly designed and constructed of high-quality materials.
Reliable power connectivity
The cable provides a consistent power source with a 4-pin USB Type-A connector on one end and a 5.5 mm DC jack on the other, ideal for a variety of applications. -
Environmentally friendly design
This product complies with RoHS standards, ensuring that the materials used are safe for the environment and contribute to sustainable practices. -
Durable molded construction
The molded design enhances the longevity of the cable, improving its performance and reducing wear and tear during regular use. -
Suitable length
At 3 ft long, this cable is versatile for different setups, convenient for both home and workplace environments. -
Secure male connectors
The male connectors on both ends of the cable ensure a tight fit, minimizing the chances of accidental disconnection during use.
 - StarTech.com 3 ft USB to Type M Barrel 5V DC Power Cable - Power cable - USB (power only) (M) to DC jack 5.5 mm (M) - 3 ft - molded - black - USB2TYPEM - power cable - USB (power only) to DC jack 5.5 mm - 91 cm
 - Power cable
 - Molded
- Length
 - 91 cm
- Connector
 - 4 pin USB Type A (power only) - male
- Connector (Second End)
 - Power DC jack 5.5 mm - male
 - Black
 - Limited lifetime warranty
- Designed For
 - P/N: DVI2VGACON, SPDIF2AA, ST122LE, ST122LEA, ST122PROA
 - Power cable
 - Molded
- Length
 - 91 cm
 - Black
- Connector
 - RoHS
- Designed For
                        StarTech.com 6 ft USB Y Cable for External Hard Drive - USB A to mini B | In Stock | £5.00 |
                        StarTech.com 3 ft USB to Type M Barrel 5V DC Power Cable | In Stock | £5.05 |
                        StarTech.com 3 ft USB to Type H Barrel 5V DC Power Cable | In Stock | £4.46 |
                        StarTech.com 2m USB to Type M Barrel Cable - USB to 5.5mm 5V DC Cable | In Stock | £5.69 |
