StarTech.com 3 ft USB to Type M Barrel 5V DC Power Cable
Quicklinx: 76QXWS00 Mfr#: USB2TYPEM
Type: Power
10 In Stock
£5.04 ex VAT
£6.04 inc VAT
Power your 5V DC devices from your computer through a USB port. Tired of having to carry around a separate wall adapter in order to power or charge your 5V devices, such as certain external hard drives, streaming media players, and Bluetooth speakers?
This USB power cable makes it easier to power 5V DC devices that have a Type M barrel power connector. You can power or charge the devices through an available USB port on your laptop or desktop computer. Expertly designed and constructed of high-quality materials.
  • Reliable power connectivity
    The cable provides a consistent power source with a 4-pin USB Type-A connector on one end and a 5.5 mm DC jack on the other, ideal for a variety of applications.
  • Environmentally friendly design
    This product complies with RoHS standards, ensuring that the materials used are safe for the environment and contribute to sustainable practices.
  • Durable molded construction
    The molded design enhances the longevity of the cable, improving its performance and reducing wear and tear during regular use.
  • Suitable length
    At 3 ft long, this cable is versatile for different setups, convenient for both home and workplace environments.
  • Secure male connectors
    The male connectors on both ends of the cable ensure a tight fit, minimizing the chances of accidental disconnection during use.
StarTech.com 3 ft USB to Type M Barrel 5V DC Power Cable - Power cable - USB (power only) (M) to DC jack 5.5 mm (M) - 3 ft - molded - black - USB2TYPEM - power cable - USB (power only) to DC jack 5.5 mm - 91 cm
Power cable
Molded
Length
91 cm
Connector
4 pin USB Type A (power only) - male
Connector (Second End)
Power DC jack 5.5 mm - male
P/N: DVI2VGACON, SPDIF2AA, ST122LE, ST122LEA, ST122PROA
Power cable
Molded
Length
91 cm
Connector
RoHS
76QX StarTech.com 3 ft USB to Type M Barrel 5V DC Power Cable In Stock £5.04
76QX StarTech.com 3 ft USB to Type H Barrel 5V DC Power Cable In Stock £4.46
76QX StarTech.com 2m USB to Type M Barrel Cable - USB to 5.5mm 5V DC Cable In Stock £5.69
Type: Power
