Extend the connection between your DB9 serial devices by up to 3 ft. The MXT1003 Serial Extension Cable features one DB9 male connector and one DB9 female connector, providing a high quality extension for your serial devices which enables you to position your peripheral devices as needed.
This DB9 extension cable is expertly designed and constructed of top quality materials to ensure durability.
- StarTech.com 3 ft / 91cm Straight Through Serial Cable - DB9 Male to Female Serial Extension Cable 3ft (MXT1003) - serial extension cable - DB-9 to DB-9 - 90 cm
- Serial extension cable
- Length
- 90 cm
- Connector
- 9 pin D-Sub (DB-9) - male
- Connector (Second End)
- 9 pin D-Sub (DB-9) - female
- Grey
- Limited lifetime warranty
- Designed For
- P/N: IC232TTL, ICUSB232D, ICUSB232IS, PCI2S5502, PEX2S953, PEX2S953LP, PEX4S953, PEX4S953LP
- American Wire Gauge (AWG)
- 28
- Length
- 90 cm
- Grey
- Connector
- RoHS
- Designed For
