StarTech.com 3 ft Standard HDMI Cable for Panel Mount - F/M
Quicklinx: 6PDZWS00 Mfr#: HDMIPNLFM3
Type: HDMI
Length: 91cm
More than 50 in stock
£8.45 ex VAT
£10.14 inc VAT
Allows an HDMI connection to be mounted on a secure and easily accessible panel. The HDMIPNLFM3 3ft Standard HDMI Cable for Panel Mount features an HDMI male connector on one end, and an HDMI panel mount (female) molded connector on the other, providing a well-secured, easy to access HDMI connection on any machine port or faceplate.
StarTech.com 3 ft. (0.9 m) HDMI Female to Male Adapter - Mounting - HDMI - HDMI Female to Male (HDMIPNLFM3) - HDMI cable - 91 cm
Cable
HDMI cable
American Wire Gauge (AWG)
28
Length
91 cm
Connector
HDMI - female
Connector (Second End)
HDMI - male
Molded
P/N: CDP2HDMM2MB, DP2HDMM2MB, HDDVIMM3, HDMIDVIMM10, HDMIDVIMM6, HDMM10, HDMM12, HDMM15, HDMM1MP, HDMM25, HDMM2M, HDMM2MP, HDMM3, HDMM3MP, HDMM50, HDMM50A, HDMM6, HDPMM50, MDP2HDMM2MB
Cable Type
HDMI cable molded
28
Jacket Material
PVC
Length
91 cm
Connector
19 pin HDMI Type A - female
19 pin HDMI Type A - male
RoHS
Limited warranty - lifetime
6PDZ StarTech.com 6 ft HDMI to DVI-D Cable - M/M In Stock £8.25
6PDZ StarTech.com HDMI to DVI-D Video Cable Adapter - F/M In Stock £8.69
6PDZ StarTech.com HDMI to DVI-D Video Cable Adapter - M/F In Stock £8.69
6PDZ StarTech.com 1 ft Panel Mount USB Cable A to A - F/M In Stock £4.69
6PDZ StarTech.com 1 ft Panel Mount USB Cable - USB A to Motherboard Header Cable F/F In Stock £4.69
6PDZ StarTech.com 1 ft Panel Mount USB Cable B to B - F/M In Stock £6.29
6PDZ StarTech.com 3ft DisplayPort Panel Mount Cable - F/M In Stock £12.24
6PDZ StarTech.com 3 ft Standard HDMI Cable for Panel Mount - F/M In Stock £8.45
6PDZ StarTech.com HDMI Coupler / Gender Changer - F/F In Stock £7.80
6PDZ StarTech.com 6in High Speed HDMI 2.0 Port Saver Cable with 4K 60Hz - Grip In Stock £11.68
Type: HDMI
Length: 91cm
Stock Status: In stock
