The MU3MMSRA 3ft stereo audio cable features one right angle stereo audio connector and one 3.5mm (straight) connector with a slim connector molding that makes this the perfect solution for portable audio devices (iPod, iPhone, iPad, MP3 Players), even if the device is in a protective case.
For those difficult to reach areas, the 3.5mm stereo audio to 3.5mm right angle cable allows you to connect where a normal straight stereo audio connector cannot.
Designed and constructed for maximum durability.
 - StarTech.com 3 ft. (0.9 m) 3.5mm Audio Cable - 3.5mm Slim Audio Cable - Right Angle - Male/Male - Aux Cable (MU3MMSRA) - audio cable - 91 cm
- Cable
 - Audio cable
- American Wire Gauge (AWG)
 - 30
- Length
 - 91 cm
 - Black
- Connector
 - Mini-phone stereo 3.5 mm - male
- Connector (Second End)
 - Right-angled connector
 - Limited lifetime warranty
- Designed For
 - P/N: SV231DVGAU2A, SV431DVGAU2A
- Cable Type
 - Audio cable right-angled connector
 - 30
- Jacket Material
 - PVC
- Length
 - 91 cm
- Plated Connector
 - Gold
 - Moulded
 - Black
- Connector
 - RoHS
 - Limited warranty - lifetime
- Designed For
                        StarTech.com 1 ft Slim 3.5mm Stereo Audio Cable - M/M | In Stock | £4.50 |
                        StarTech.com 10 ft Slim 3.5mm Stereo Audio Cable - M/M | In Stock | £5.00 |
                        StarTech.com 15 ft Slim 3.5mm Stereo Audio Cable - M/M | In Stock | £5.48 |
                        StarTech.com 1 ft Slim 3.5mm Right Angle Stereo Audio Cable - M/M | In Stock | £2.88 |
                        StarTech.com 3.5 Right Angle Stereo Cable | In Stock | £4.48 |
                        StarTech.com 3 ft Slim 3.5mm Stereo Audio Cable - M/M | In Stock | £3.06 |
                        StarTech.com 3 ft Slim 3.5mm Right Angle Stereo Audio Cable - M/M | In Stock | £4.40 |
                        StarTech.com 6 ft Slim 3.5mm Stereo Audio Cable - M/M | In Stock | £3.78 |
                        StarTech.com 2m 3.5mm 4 Position TRRS Headset Extension Cable - M/F | In Stock | £6.14 |
