StarTech.com 3 ft Slim 3.5mm to Right Angle Stereo Audio Cable - M/M
Quicklinx: 7B60WS00 Mfr#: MU3MMSRA
Type: Audio
Length: 91cm
£4.42 ex VAT
£5.30 inc VAT
The MU3MMSRA 3ft stereo audio cable features one right angle stereo audio connector and one 3.5mm (straight) connector with a slim connector molding that makes this the perfect solution for portable audio devices (iPod, iPhone, iPad, MP3 Players), even if the device is in a protective case.
For those difficult to reach areas, the 3.5mm stereo audio to 3.5mm right angle cable allows you to connect where a normal straight stereo audio connector cannot.
Designed and constructed for maximum durability.
StarTech.com 3 ft. (0.9 m) 3.5mm Audio Cable - 3.5mm Slim Audio Cable - Right Angle - Male/Male - Aux Cable (MU3MMSRA) - audio cable - 91 cm
Cable
Audio cable
American Wire Gauge (AWG)
30
Length
91 cm
Connector
Mini-phone stereo 3.5 mm - male
Connector (Second End)
Right-angled connector
P/N: SV231DVGAU2A, SV431DVGAU2A
Cable Type
Audio cable right-angled connector
30
Jacket Material
PVC
Length
91 cm
Plated Connector
Gold
Moulded
Connector
RoHS
Limited warranty - lifetime
7B60 StarTech.com 1 ft Slim 3.5mm Stereo Audio Cable - M/M In Stock £4.58
7B60 StarTech.com 10 ft Slim 3.5mm Stereo Audio Cable - M/M In Stock £5.00
7B60 StarTech.com 15 ft Slim 3.5mm Stereo Audio Cable - M/M In Stock £5.63
7B60 StarTech.com 3.5 Right Angle Stereo Cable In Stock £4.28
7B60 StarTech.com 3 ft Slim 3.5mm Stereo Audio Cable - M/M In Stock £3.06
7B60 StarTech.com 3 ft Slim 3.5mm Right Angle Stereo Audio Cable - M/M In Stock £4.40
7B60 StarTech.com 3 ft Slim 3.5mm to Right Angle Stereo Audio Cable - M/M In Stock £4.42
7B60 StarTech.com 6 ft Slim 3.5mm Stereo Audio Cable - M/M In Stock £3.79
7B60 StarTech.com 2m 3.5mm 4 Position TRRS Headset Extension Cable - M/F In Stock £5.66
Type: Audio
Length: 91cm
