The MU3MMSRA 3ft stereo audio cable features one right angle stereo audio connector and one 3.5mm (straight) connector with a slim connector molding that makes this the perfect solution for portable audio devices (iPod, iPhone, iPad, MP3 Players), even if the device is in a protective case.
For those difficult to reach areas, the 3.5mm stereo audio to 3.5mm right angle cable allows you to connect where a normal straight stereo audio connector cannot.
Designed and constructed for maximum durability.
- StarTech.com 3 ft. (0.9 m) 3.5mm Audio Cable - 3.5mm Slim Audio Cable - Right Angle - Male/Male - Aux Cable (MU3MMSRA) - audio cable - 91 cm
- Cable
- Audio cable
- American Wire Gauge (AWG)
- 30
- Length
- 91 cm
- Black
- Connector
- Stereo mini jack - male
- Connector (Second End)
- Right-angled connector
- Limited lifetime warranty
- Designed For
- P/N: SV231DVGAU2A, SV431DVGAU2A
- Cable Type
- Audio cable right-angled connector
- 30
- Jacket Material
- PVC
- Length
- 91 cm
- Plated Connector
- Gold
- Moulded
- Black
- Connector
- Mini-phone stereo 3.5 mm - male
- RoHS
- Limited warranty - lifetime
- Designed For
