Easily connect an iPod or other MP3 player to a car stereo.
This 3-foot Slim 3.5mm Right Angle to Right Angle Stereo Audio Cable is the perfect solution for portable audio devices (iPod, iPhone, iPad, MP3 Players), featuring a slim connector molding that fits easily into a 3.5mm headphone jack, even if the device is in a protective case.
For those difficult to reach areas, our Right Angle 3.5mm stereo audio to 3.5mm right angle cable allows you to connect where a normal (straight) stereo audio connector cannot.
Slim and flexible design
The 3 ft Slim 3.5mm Right Angle Stereo Audio Cable features a slim, flexible design that makes it easy to fit in tight spaces and prevents tangling, ensuring a neat and organized setup. -
High-quality audio connection
With gold-plated connectors, this audio cable ensures a reliable connection that delivers crisp, clear sound without interference or signal loss. -
Durable construction
Constructed with a PVC jacket and an American Wire Gauge (AWG) of 30, this cable is designed for durability and long-lasting performance, resisting wear and tear from daily use.
- StarTech.com 3 ft Slim 3.5mm Right Angle Stereo Audio Cable - M/M (MU3MMS2RA) - audio cable - 91 cm
- Cable
- Audio cable
- American Wire Gauge (AWG)
- 30
- Length
- 91 cm
- Black
- Connector
- Mini-phone stereo 3.5 mm - male
- Connector (Second End)
- Right-angled connector
- Limited lifetime warranty
- Cable Type
- Audio cable right-angled connector
- 30
- Jacket Material
- PVC
- Length
- 91 cm
- Plated Connector
- Gold
- Black
- Connector
- RoHS
- Limited warranty - lifetime
StarTech.com 10 ft Slim 3.5mm Stereo Audio Cable - M/M | In Stock | £5.37 |
StarTech.com 1 ft Slim 3.5mm Right Angle Stereo Audio Cable - M/M | In Stock | £2.97 |
StarTech.com 3.5 Right Angle Stereo Cable | In Stock | £4.51 |
StarTech.com 3 ft Slim 3.5mm Stereo Audio Cable - M/M | In Stock | £2.97 |
StarTech.com 6 ft Slim 3.5mm Stereo Audio Cable - M/M | In Stock | £3.97 |
StarTech.com 2m 3.5mm 4 Position TRRS Headset Extension Cable - M/F | In Stock | £6.20 |
