StarTech.com 3 ft Slim 3.5mm Right Angle Stereo Audio Cable - M/M
Quicklinx: 7B5ZWS00 Mfr#: MU3MMS2RA
Type: Audio
Length: 91cm
Hurry, only 3 left in stock!
£4.47 ex VAT
£5.36 inc VAT
Easily connect an iPod or other MP3 player to a car stereo.
This 3-foot Slim 3.5mm Right Angle to Right Angle Stereo Audio Cable is the perfect solution for portable audio devices (iPod, iPhone, iPad, MP3 Players), featuring a slim connector molding that fits easily into a 3.5mm headphone jack, even if the device is in a protective case.
For those difficult to reach areas, our Right Angle 3.5mm stereo audio to 3.5mm right angle cable allows you to connect where a normal (straight) stereo audio connector cannot.
  • Slim and flexible design
    The 3 ft Slim 3.5mm Right Angle Stereo Audio Cable features a slim, flexible design that makes it easy to fit in tight spaces and prevents tangling, ensuring a neat and organized setup.
  • High-quality audio connection
    With gold-plated connectors, this audio cable ensures a reliable connection that delivers crisp, clear sound without interference or signal loss.
  • Durable construction
    Constructed with a PVC jacket and an American Wire Gauge (AWG) of 30, this cable is designed for durability and long-lasting performance, resisting wear and tear from daily use.
StarTech.com 3 ft Slim 3.5mm Right Angle Stereo Audio Cable - M/M (MU3MMS2RA) - audio cable - 91 cm
Cable
Audio cable
30
Length
91 cm
Connector
Mini-phone stereo 3.5 mm - male
Connector (Second End)
Right-angled connector
Cable Type
Audio cable right-angled connector
30
Jacket Material
PVC
Length
91 cm
Plated Connector
Gold
Connector
RoHS
Limited warranty - lifetime
7B5Z StarTech.com 10 ft Slim 3.5mm Stereo Audio Cable - M/M In Stock £5.37
7B5Z StarTech.com 15 ft Slim 3.5mm Stereo Audio Cable - M/M In Stock £5.56
7B5Z StarTech.com 1 ft Slim 3.5mm Right Angle Stereo Audio Cable - M/M In Stock £2.97
7B5Z StarTech.com 3.5 Right Angle Stereo Cable In Stock £4.51
7B5Z StarTech.com 3 ft Slim 3.5mm Stereo Audio Cable - M/M In Stock £2.97
7B5Z StarTech.com 3 ft Slim 3.5mm Right Angle Stereo Audio Cable - M/M In Stock £4.47
7B5Z StarTech.com 3 ft Slim 3.5mm to Right Angle Stereo Audio Cable - M/M In Stock £4.49
7B5Z StarTech.com 6 ft Slim 3.5mm Stereo Audio Cable - M/M In Stock £3.97
7B5Z StarTech.com 2m 3.5mm 4 Position TRRS Headset Extension Cable - M/F In Stock £6.20
Type: Audio
Length: 91cm
