This 3 ft eSATA + USB Cable features two male eSATA/USB combo connectors, allowing you make a direct link between devices equipped with USB and eSATA combination ports.
An ideal solution for connecting external hard drive enclosures to your laptop or desktop computer, this high quality cable provides a full speed eSATA connection combined with a USB connection that can be used to power the external storage (where supported) - even if using a laptop computer running on battery power.
StarTech.com 3 ft Power eSATA Cable - M/M - Power Over eSATA cable - 91 cm
Length
91 cm
Connector
11 pin USB/eSATA - male
Connector (Second End)
P/N: S251SMU33EP
Storage Cable Type
Length
91 cm
Connector
RoHS
P/N: S251SMU33EP
