Brand
StarTech.com 3 ft Panel Mount USB Cable B to B - F/M
Quicklinx: 92Q8WS00 Mfr#: USBPNLBFBM3
Length: 90cm
25 in stock
£5.22 ex VAT
£6.26 inc VAT
Panel-mount a USB-B port, for easy access. The USBPNLBFBM3 3ft Panel Mount USB Cable features one USB-B male connector on one end and a USB-B panel mount female port on the other, providing a convenient solution for custom enclosures (e.g. internally mounted hard drives).
Offering 3ft in cable length, the adapter allows you to extend the connection as needed within the system case.
StarTech.com 3 ft Panel Mount USB Cable B to B - F/M - Panel Mount USB Extension USB-B Female to USB-B Male Adapter Cable - USB-B (F) Port (USBPNLBFBM3) - USB cable - USB Type B to USB Type B - 90 cm
USB cable
Shielded
Molded
Length
90 cm
Connector
4 pin USB Type B - male
Connector (Second End)
4 pin USB Type B - female
USB / USB 2.0
P/N: USB2HAB10, USB2HAB15, USB2HAB30AC, USB2HAB50AC, USB2HAB6, USB2HABM1, USB2HABM6RA
USB cable
Shielded
American Wire Gauge (AWG)
24/28
Plated Connector
Nickel
Molded
Length
90 cm
Connector
USB / USB 2.0, RoHS
92Q8 StarTech.com 1 ft Panel Mount USB Cable B to B - F/M In Stock £6.27
Length: 90cm
Stock Status: In stock
