StarTech.com 3 ft Panel Mount USB Cable A to B - F/M
Quicklinx: 93FPWS00 Mfr#: USBPNLAFBM3
Mount your USB device internally and connect to it through a panel mount USB-A connection. The USBPNLAFBM3 3ft Panel Mount USB-B Cable provides a well-secured, easy to access USB-A port on your PC or on a faceplate, allowing you to customize your systems to suit your needs. Perfect for podiums, kiosks and other solutions where added access to USB peripherals is required.
The adapter features one male USB-B connector and one female panel mount USB-A port allowing you to mount your USB device internally enabling you to access it through a USB-A connection. Offering 3ft in cable length, the adapter allows you to place the cable as needed within the system case.
StarTech.com 3 ft Panel Mount USB Cable A to B - F/M - USB extension cable - USB to USB Type B - 91.4 cm
USB extension cable
Double shielded
Length
91.4 cm
Connector
4 pin USB Type A - female
Connector (Second End)
4 pin USB Type B - male
USB / USB 2.0
USB extension cable
Double shielded
American Wire Gauge (AWG)
24/28
Plated Connector
Nickel
Length
91.4 cm
Connector
USB / USB 2.0, RoHS
93FP StarTech.com 10m/30ft Active USB 2.0 A to B Cable - M/M In Stock £20.17
