StarTech.com 3 ft Panel Mount USB Cable  USB A to Motherboard Header Cable F/F
Quicklinx: 92Q6WS00 Mfr#: USBPNLAFHD3
Length: 90cm
More than 50 In Stock
£6.24 ex VAT
£7.48 inc VAT
Connect a panel mount USB-A port to your motherboard header. The USBPNLAFHD3 3ft Panel Mount USB Cable enables you to add a well-secured, easy to access USB 2.0 port to your PC, offering a convenient solution for connecting bootable thumb drives or authentication fobs etc. to the motherboard USB connection.
The adapter features one female USB header connector and one female panel mount USB-A port and gives you an extension of 3ft, enabling you to place the cable as needed within the system case.
StarTech.com 3 ft Panel Mount USB A to Motherboard Header Cable F/F - USB internal to external cable - 5 pin USB 2.0 header to USB - 90 cm
Length
90 cm
Connector
5 pin USB 2.0 header - female
Connector (Second End)
4 pin USB Type A - female
USB / USB 2.0
American Wire Gauge (AWG)
24/28
Length
90 cm
Connector
USB / USB 2.0
Length: 90cm
