Connect your (USB Mini) portable device to a host computer through a standard USB 2.0 type-A slot. The USB2HABM50CM 0.5-meter (50cm) USB ''A'' to Mini ''B'' Cable provides one (4-pin) USB Type ''A'' male connector and one Mini ''B'' (5-pin) male connector, with support for high-speed USB 2.0 transfer rates up to 480Mbps.
A high quality replacement for connecting your digital camera to a host computer, this durable USB 2.0 cable also delivers a cost-effective way to maximize the file transfer performance of your MP3 player, PDA, or digital camcorder.
Expertly designed and constructed of only top quality materials, the A-to-Mini B USB 2.0 cable offers pure digital data transfers for sharper, more natural images and sound at higher speeds.
Reliable connectivity
The cable features male connectors on both ends, ensuring consistent and stable connections with compatible devices. -
Robust construction
Built with a double shielded design, this cable minimizes interference, providing a dependable data transfer experience. -
Environmentally friendly
This product is RoHS compliant, which means it meets strict environmental standards for hazardous substances. -
Flexible design
At 0.5 meters in length, this cable is compact and ideal for use in tight spaces without sacrificing performance.
- StarTech.com 0.5m Mini USB 2.0 Cable A to Mini B M/M - USB cable - USB to mini-USB Type B - 50 cm
- USB cable
- Technology
- Double shielded
- Length
- 50 cm
- Connector
- 4 pin USB Type A - male
- Connector (Second End)
- Mini-USB Type B - male
- USB / USB 2.0
- Black
- Limited lifetime warranty
- USB cable
- Technology
- Double shielded
- American Wire Gauge (AWG)
- 28
- Length
- 50 cm
- Black
- Connector
- USB / USB 2.0, RoHS
StarTech.com Mini USB to Micro USB Adapter | In Stock | £3.62 |
StarTech.com 1m Mini USB 2.0 Cable - A to Mini B - M/M | In Stock | £3.70 |
StarTech.com 2m Mini USB 2.0 Cable - A to Mini B - M/M | In Stock | £2.00 |
StarTech.com 3 ft Mini USB Cable - A to Right Angle Mini B | In Stock | £3.32 |
