StarTech.com 3 ft Mini USB Cable - A to Right Angle Mini B
Quicklinx: 7WZBWS00 Mfr#: USB2HABM50CM
Length: 50cm
18 In Stock
£3.32 ex VAT
£3.98 inc VAT
Connect your (USB Mini) portable device to a host computer through a standard USB 2.0 type-A slot. The USB2HABM50CM 0.5-meter (50cm) USB ''A'' to Mini ''B'' Cable provides one (4-pin) USB Type ''A'' male connector and one Mini ''B'' (5-pin) male connector, with support for high-speed USB 2.0 transfer rates up to 480Mbps.
A high quality replacement for connecting your digital camera to a host computer, this durable USB 2.0 cable also delivers a cost-effective way to maximize the file transfer performance of your MP3 player, PDA, or digital camcorder.
Expertly designed and constructed of only top quality materials, the A-to-Mini B USB 2.0 cable offers pure digital data transfers for sharper, more natural images and sound at higher speeds.
  • Reliable connectivity
    The cable features male connectors on both ends, ensuring consistent and stable connections with compatible devices.
  • Robust construction
    Built with a double shielded design, this cable minimizes interference, providing a dependable data transfer experience.
  • Environmentally friendly
    This product is RoHS compliant, which means it meets strict environmental standards for hazardous substances.
  • Flexible design
    At 0.5 meters in length, this cable is compact and ideal for use in tight spaces without sacrificing performance.
StarTech.com 0.5m Mini USB 2.0 Cable A to Mini B M/M - USB cable - USB to mini-USB Type B - 50 cm
USB cable
Double shielded
Length
50 cm
Connector
4 pin USB Type A - male
Connector (Second End)
Mini-USB Type B - male
USB / USB 2.0
USB cable
Double shielded
American Wire Gauge (AWG)
28
Length
50 cm
Connector
USB / USB 2.0, RoHS
7WZB StarTech.com Mini USB to Micro USB Adapter In Stock £4.58
7WZB StarTech.com 1m Mini USB 2.0 Cable - A to Mini B - M/M In Stock £3.71
7WZB StarTech.com 2m Mini USB 2.0 Cable - A to Mini B - M/M In Stock £2.00
7WZB StarTech.com 3 ft Mini USB Cable - A to Right Angle Mini B In Stock £3.32
Length: 50cm
