StarTech.com 3 ft Mini USB Cable - A to Left Angle Mini B
Quicklinx: 7P3VWS00 Mfr#: USB2HABM3LA
Length: 91cm
12 in stock
£3.39 ex VAT
£4.06 inc VAT
Connect your Mini USB devices, with the cable out of the way. The USB2HABM3LA 3ft USB to Left Angle Mini USB Cable provides a high quality connection between your Mini USB 2.0 mobile devices (smartphones, GPS, digital cameras, portable hard drives, etc.) and your PC or Mac computer, for everyday tasks such as charging, data synchronization or file transfers.
The left-angled Mini USB connector allows you to access your Mini USB devices, while keeping the cable out of the way, and stress away from the port.
As an alternative, StarTech.com also offers a USB2HABM3RA 3ft USB A to Right Angle Mini B, which provides the same convenience as this left-angled cable, but allows you to connect to your Mini USB device from the opposite direction.
StarTech.com 3 ft. (0.9 m) Left Angle Mini USB Cable - USB 2.0 A to Left Angle Mini B - Black - Mini USB Cable (USB2HABM3LA) - USB cable - 91 cm
USB cable
90° connector, left-angled connector
Length
91 cm
Connector
4 pin USB Type A - male
Connector (Second End)
Mini-USB Type B - male
USB / USB 2.0
P/N: SV565HDIP
USB cable
American Wire Gauge (AWG)
28
Length
91 cm
Connector
USB / USB 2.0, RoHS
P/N: SV565HDIP
7P3V StarTech.com 1ft Micro USB Cable - A to Micro B In Stock £3.73
7P3V StarTech.com 1 ft Micro USB Cable - A to Left Angle Micro B In Stock £1.87
7P3V StarTech.com 1 ft Micro USB Cable - A to Right Angle Micro B In Stock £3.81
7P3V StarTech.com 6 ft Micro USB Cable A to Left Angle Micro B In Stock £4.86
7P3V StarTech.com 3 ft Mini USB Cable - A to Left Angle Mini B In Stock £3.39
7P3V StarTech.com 3ft Right Angle Mini USB Cable In Stock £3.39
7P3V StarTech.com 6 ft Mini USB Cable - A to Left Angle Mini B In Stock £3.54
7P3V StarTech.com 6 ft Mini USB Cable - A to Right Angle Mini B In Stock £3.55
Length: 91cm
Price Range Ex VAT: 0 - 50
