Product
StarTech.com 3 ft Mini DisplayPort to VGA Adapter Converter Cable – mDP to VGA 1920x1200 - Black
Quicklinx: 907LWS00 Mfr#: MDP2VGAMM3B
More than 50 in stock
£18.18 ex VAT
£21.81 inc VAT
Connect a Mini DisplayPort-equipped PC or Mac to a nearby VGA monitor/projector, with a short 3ft black cable. The MDP2VGAMM3B active Mini DisplayPort to VGA converter cable lets you connect your Mini DisplayPort-equipped desktop or laptop directly to a nearby VGA monitor or projector, saving the expense of additional adapters while eliminating the clutter of excess cable.
The adapter cable is compatible with Intel Thunderbolt, when connected directly to a supporting DisplayPort over Thunderbolt I/O port. Plus, because the converter cable supports video resolutions up to 1920x1200 you can convert a DisplayPort video source to VGA without sacrificing video quality.
StarTech.com 3ft Mini DisplayPort to VGA Adapter Cable mDP to VGA Black - video converter - black
Video converter
Max Resolution
1920 x 1200
1 x DisplayPort output - Mini DisplayPort , 1 x VGA input - 15 pin HD D-Sub (HD-15)
Enclosure Colour
2 years warranty
Video converter
Max Resolution
1920 x 1200
1 x DisplayPort output - Mini DisplayPort - male , 1 x VGA input - 15 pin HD D-Sub (HD-15) - male
Active cable (signal regeneration), Thunderbolt port compatible
1 - 90 cm
FCC, RoHS, WEEE
79 g
Enclosure Colour
60 °C
40 - 85%
Price Range Ex VAT: 0 - 50
