Connect a Mini DisplayPort-equipped PC or Mac to a nearby VGA monitor/projector, with a short 3ft black cable. The MDP2VGAMM3B active Mini DisplayPort to VGA converter cable lets you connect your Mini DisplayPort-equipped desktop or laptop directly to a nearby VGA monitor or projector, saving the expense of additional adapters while eliminating the clutter of excess cable.
The adapter cable is compatible with Intel Thunderbolt, when connected directly to a supporting DisplayPort over Thunderbolt I/O port. Plus, because the converter cable supports video resolutions up to 1920x1200 you can convert a DisplayPort video source to VGA without sacrificing video quality.
- StarTech.com 3 ft Mini DisplayPort to VGA Adapter Cable - mDP to VGA Video Converter - Mini DP to VGA Cable for Mac / PC 1920x1200 - Black (MDP2VGAMM3B) - video converter - black
- Video converter
- Max Resolution
- 1920 x 1200
- 1 x DisplayPort output - Mini DisplayPort , 1 x VGA input - 15 pin HD D-Sub (HD-15)
- Enclosure Colour
- Black
- 3-year warranty
- Video converter
- Max Resolution
- 1920 x 1200
- 1 x DisplayPort output - Mini DisplayPort - male , 1 x VGA input - 15 pin HD D-Sub (HD-15) - male
- Active cable (signal regeneration), Thunderbolt port compatible
- Cables Included
- 1 - 90 cm
- FCC, RoHS, WEEE
- 79 g
- Enclosure Colour
- Black
- Limited warranty - 3 years
- 0 °C
- 60 °C
- 40 - 85%
StarTech.com Mini DisplayPort to VGA Video Adapter Converter | In Stock | £16.84 |
StarTech.com Mini DisplayPort to VGA Video Adapter Converter - White | In Stock | £5.38 |
StarTech.com 6 ft Mini DisplayPort to VGA Adapter Converter Cable – mDP to VGA 1920x1200 - Black | In Stock | £20.53 |
StarTech.com 3 ft DisplayPort to VGA Adapter Converter Cable – DP to VGA 1920x1200 - Black | In Stock | £19.83 |
StarTech.com 15 ft Mini DisplayPort to VGA Adapter Converter Cable – mDP to VGA 1920x1200 - Black | In Stock | £23.34 |
StarTech.com 10 ft DisplayPort to VGA Adapter Converter Cable – DP to VGA 1920x1200 - Black | In Stock | £23.68 |
StarTech.com 15 ft DisplayPort to VGA Adapter Converter Cable – DP to VGA 1920x1200 - Black | In Stock | £6.99 |
StarTech.com Mini DisplayPort 1.2 to VGA Adapter Converter – Mini DP to VGA – 1920x1200 | In Stock | £16.14 |
