Brand
StarTech.com 3 ft Mini DisplayPort to DVI Active Adapter Converter Cable – 2560x1600  Black
Quicklinx: 964WWS00 Mfr#: MDP2DVIMM3BS
Length: 90cm
More than 50 in stock
£21.29 ex VAT
£25.54 inc VAT
Eliminate excess cable clutter with a short 3ft Mini DisplayPort to DVI active adapter. The MDP2DVIMM3BS 3ft active Mini DisplayPort to DVI adapter cable lets you directly connect your Mini DP video source (Laptop, Macbook, Ultrabook etc.) directly to a nearby DVI monitor or projector, saving the expense of additional adapters while eliminating the clutter of excess cable.
For guaranteed compatibility with virtually any Mini DisplayPort output the active Mini DP to DVI adapter supports multimode (DP++) as well as single-mode DisplayPort signals. Unlike passive adapters, this ensures the MDP2DVIMM3BS can be used with graphics cards that are not capable of outputting multimode DP++ signals, such as ATI Eyefinity cards.
Compatible with Intel Thunderbolt, when connected directly to a supporting DisplayPort over Thunderbolt I/O port, the adapter supports resolutions up to 2560x1600.
StarTech.com 3 ft Mini DisplayPort to DVI Active Adapter Converter Cable - 3ft (0.9m) Active mDP to DVI M/M Cable for PC 1920x1200 - Black (MDP2DVIMM3BS) - DisplayPort cable - 90 cm
DisplayPort cable
Active cable (signal regeneration)
Length
90 cm
Connector
Mini DisplayPort - male
Connector (Second End)
DVI-D - male
FCC, RoHS
3-year warranty
DisplayPort cable
Length
90 cm
Connector
24+1 pin digital DVI - male
FCC, RoHS
3-year warranty
964W StarTech.com Mini DisplayPort to DVI Video Adapter Converter In Stock £10.54
964W StarTech.com 6 ft Mini DisplayPort to DVI Cable - M/M In Stock £23.28
964W StarTech.com Mini DisplayPort to DVI Video Adapter Converter - White In Stock £10.54
964W StarTech.com Mini DisplayPort to DVI Video Adapter Converter - Black Mini DP to DVI - 1920x1200 In Stock £10.54
964W StarTech.com 6 ft Mini DisplayPort to DVI Adapter Converter Cable – Mini DP to DVI 1920x1200 - Black In Stock £14.78
964W StarTech.com 3 ft DisplayPort to DVI Active Adapter Converter Cable – DP to DVI 2560x1600 – Black In Stock £21.29
964W StarTech.com 6 ft Mini DisplayPort to DVI Active Adapter Converter Cable - 2560x1600 – Black In Stock £24.38
964W StarTech.com 6 ft Mini DisplayPort to DVI Active Adapter Converter Cable – 2560x1600 – White In Stock £24.38
964W StarTech.com 3 ft Mini DisplayPort to DVI Active Adapter Converter Cable – DVI 2560x1600 – White In Stock £21.29
964W StarTech.com 6 ft DisplayPort to DVI Active Adapter Converter Cable – DP to DVI 2560x1600 – Black In Stock £24.38
964W StarTech.com 3 ft Mini DisplayPort to DVI Active Adapter Converter Cable – 2560x1600 Black In Stock £21.29
Length: 90cm
Stock Status: In stock
