Charge your power-hungry mobile devices with this 24AWG Micro-USB cable. This 30/24 Micro-USB cable features 24 AWG wire to provide the full power you need to charge your mobile devices faster.
Plus, the right-angled Micro-USB connector is great for charging your mobile devices in a car, or for accessing your mobile device while it's connected to a wall charger or computer.
Different phones and tablets require specific amounts of power to charge efficiently. While a phone may only require 1.0A of power, a tablet may need 2.4A.
This 30/24 cable is designed to deliver full power to your mobile devices so that all of your devices can charge at the expected speed.
The right-angled Micro-USB connector lets you connect to ports that are difficult to reach, which is perfect for charging your car-mounted mobile devices. Even while you're charging your mobile device, you can use it to text, work or game, without the cable getting in the way.
The angled connector also prevents the cable from bending awkwardly or from straining too much to make a connection. It offers a more natural fit at the connection point, preventing unnecessary stress and damage to the cable and device port.
Replace the Micro-USB cable that came with your mobile device, or keep one as a spare while traveling so that your mobile devices will be ready to use while you're on the road.
- StarTech.com 1m 3 ft Micro-USB Charge-and-Sync Cable - Right-Angle Micro-USB - M/M - USB to Micro USB Charging Cable - 30/24 AWG (USBAUB1MRA) - USB cable - Micro-USB Type B to USB - 1 m
- USB cable
- Technology
- Double shielded
- Right-angled connector, sync and charge
- Length
- 1 m
- Connector
- 5 pin Micro-USB Type B - male
- Connector (Second End)
- 4 pin USB Type A - male
- USB / USB 2.0
- Black
- Limited lifetime warranty
- Designed For
- P/N: USB2PCARBK, USB2PCARBKS, USBEXTAA10BK, USBEXTAA3BK, USBEXTAA6BK, USBLT2PCARW, USBUB2PCARB
- USB cable
- Technology
- Double shielded
- American Wire Gauge (AWG)
- 24/30
- Plated Connector
- Nickel
- Length
- 1 m
- Black
- Connector
- USB / USB 2.0, RoHS
- Designed For
StarTech.com 6in Micro USB Cable - A to Micro B | In Stock | £4.61 |
StarTech.com 3ft Micro-USB Charging Cable | In Stock | £5.00 |
StarTech.com 3 ft Micro-USB Charging Cable | In Stock | £5.00 |
StarTech.com 6 ft Micro-USB Charging Cable | In Stock | £8.27 |
StarTech.com 0.5m Angled Micro USB Cable | In Stock | £4.68 |
