StarTech.com 3 ft High Speed HDMI Cable with Ethernet - HDMI to HDMI Micro - M/M
Quicklinx: 7NYFWS00 Mfr#: HDMIADMM3
Connect an HDMI Micro-equipped Smartphone or Portable Device to your HDMI-capable TV or Display. The HDMIADMM3 3-foot High Speed HDMI to HDMI Micro cable lets you connect devices with a HDMI Micro port to a display/device with a standard HDMI port - a cost-saving solution for connecting cutting-edge and next-generation HDMI-capable devices to existing HDMI technology.
The HDMI/HDMI Micro cable features high-quality gold-tipped connectors that ensure peak connectivity.
  • Versatile connectivity
    This cable connects various devices, including HDMI compatible displays and micro HDMI devices, allowing for flexible setup and use in different environments.
  • Efficient transmission
    With support for high-speed data transfer, this cable ensures smooth streaming of high-definition video and audio, enhancing the viewing experience.
StarTech.com 3 ft High Speed HDMI Cable with Ethernet - HDMI to HDMI Micro - M/M (HDMIADMM3) - HDMI cable with Ethernet - 91 cm
Cable
American Wire Gauge (AWG)
34
Length
91 cm
Connector
HDMI - male
Connector (Second End)
19 pin micro HDMI Type D - male
Cable Type
34
Jacket Material
PVC
Length
91 cm
Plated Connector
Gold
Connector
19 pin HDMI Type A - male
RoHS
Limited warranty - lifetime
7NYF StarTech.com 5in High Speed HDMI Adapter Cable - HDMI to HDMI Micro – F/M In Stock £12.43
7NYF StarTech.com HDMI Coupler / Gender Changer - F/F In Stock £8.59
