StarTech.com 3 ft HD15 to Component RCA Breakout Cable Adapter - M/M
Quicklinx: 8657WS00 Mfr#: HD15CPNTMM3
Type: A/V
Length: 91cm
Hurry, only 1 left in stock!
£12.18 ex VAT
£14.61 inc VAT
Connect a VGA output (video card, etc.) to a display/monitor that uses Component video input. The HD15CPNTMM3 3ft HD15 to Component RCA Breakout Cable Adapter features a male VGA (HD15) connector and male component video connectors, allowing you to connect a VGA output (video card, etc.) to a display/monitor that uses Component video input.
This cable requires a video converter or output device that can process a YPbPr signal through an HD15 (VGA) port.
StarTech.com 3 ft. (0.9 m) VGA to RCA Cable - RCA Breakout - HD15 (M)/Component (M) - VGA to Component (HD15CPNTMM3) - VGA cable - 91 cm
VGA cable
Length
91 cm
Connector
HD-15 (VGA) - male
Connector (Second End)
3 x RCA - male
RoHS
P/N: DVI2VGA, VGA2HD2, VID2VGATV, VID2VGATV2, VID2VGATV3
VGA cable
Length
91 cm
Connector
3 x RCA - male
RoHS
Type: A/V
Length: 91cm
Price Range Ex VAT: 0 - 50
