Connect power eSATA devices to the eSATA and USB ports on your computer. This eSATA and USB A Male to Power eSATA Cable provides a 3 ft connection between an external drive enclosure equipped with a power eSATA port and the eSATA and USB port on a PC/notebook, providing both power (through USB) and data (through SATA) using a single cable.
The 3 ft eSATA and USB A Male to Power eSATA Male cable is expertly designed and constructed of only top quality materials.
StarTech.com eSATA and USB A to Power eSATA Cable - Power Over eSATA cable - 91 cm
Length
91 cm
Connectors
11 pin USB/eSATA - male
Connectors (Second End)
7 pin external Serial ATA - male , 4 pin USB Type A - male
P/N: S251SMU33EP
Storage Cable Type
Length
91 cm
Connectors
P/N: S251SMU33EP
