StarTech.com 3 ft DVI-D Dual Link Cable - M/M
Quicklinx: 6LBSWS00 Mfr#: DVIDDMM3
Type: DVI
Length: 91cm
38 in stock
£4.15 ex VAT
£4.98 inc VAT
Provides a high-speed, crystal-clear connection to your DVI digital devices. The DVIDDMM3 3ft DVI-D Dual Link cable features 2 male DVI (25-pin) connectors and provides a reliable, purely digital connection between your desktop or laptop computer and a DVI-D monitor or projector.
The 3 ft DVI-D digital monitor cable supports resolutions of up to 2560x1600 and transmission rates of up to 9.9 Gbits/sec and is fully compliant with DVI DDWG standards.
StarTech.com 3 ft DVI-D Dual Link Cable - M/M - DVI cable - 91 cm
DVI cable - dual link
Length
91 cm
Connector
DVI-D - male
Connector (Second End)
DVI-D - male
RoHS
P/N: SV231QDVIUA, USB32DVIEH
DVI cable
TMDS Links
Dual link
Plated Connector
Nickel
Length
91 cm
Connector
24+1 pin digital DVI - male
RoHS
Type: DVI
Length: 91cm
Price Range Ex VAT: 0 - 50
