Provides a high-speed, crystal-clear connection to your DVI digital devices. The DVIDDMM3 3ft DVI-D Dual Link cable features 2 male DVI (25-pin) connectors and provides a reliable, purely digital connection between your desktop or laptop computer and a DVI-D monitor or projector.
The 3 ft DVI-D digital monitor cable supports resolutions of up to 2560x1600 and transmission rates of up to 9.9 Gbits/sec and is fully compliant with DVI DDWG standards.
- StarTech.com Dual Link DVI Cable - 3 ft - Male to Male - 2560x1600 - DVI-D Cable - Computer Monitor Cable - DVI Cord - Video Cable (DVIDDMM3) - DVI cable - 91 cm
- DVI cable - dual link
- Length
- 91 cm
- Connector
- DVI-D - male
- Connector (Second End)
- DVI-D - male
- RoHS
- Black
- Limited lifetime warranty
- Designed For
- P/N: BNDDKTCHVPRS, CDP2DVIDP, CDP2DVIUCP, CDP2DVIUCPW, CDP2HD, CDP2HDUCP, CDPVDHDMDP2G, CDPVDHDMDPRG, CDPVDHDMDPSG, CDPVDHMDPDP, CDPVGDVHDB, CDPVGDVHDMDP, DKT30CHCPD, DKT30CHD, DKT30CHPDW, DKT30CHV, DKT30CHVW, DP2VGDVHD, DVI92030202L, HD2DPVGADVI, HDDVIMF8IN, MDP2DVI3, SV431DL2DU3A, USB32DVIEH
- DVI cable
- TMDS Links
- Dual link
- Plated Connector
- Nickel
- Length
- 91 cm
- Black
- Connector
- 24+1 pin digital DVI - male
- RoHS
- Designed For
- P/N: BNDDKTCHVPRS, CDP2DVIDP, CDP2DVIUCP, CDP2DVIUCPW, CDP2HD, CDP2HDUCP, CDPVDHDMDP2G, CDPVDHDMDPRG, CDPVDHDMDPSG, CDPVDHMDPDP, CDPVGDVHDB, CDPVGDVHDMDP, DKT30CHCPD, DKT30CHD, DKT30CHPDW, DKT30CHV, DKT30CHVW, DP2DVI, DP2DVI2, DP2DVID2, DP2DVIS, DP2VGDVHD, DVI92030202L, DVIEXTAA6IN, DVISPL1DD, HD2DPVGADVI, HDDVIMF8IN, HDMIDVIMF, MDP2DPDVHD, MDP2DVI, MDP2DVI3, MDP2DVIS, MDP2DVIW, SV231DD2DUA, SV231DDVDUA, SV231QDVIUA, SV231TDVIUA, SV431DD2DUA, SV431DDVDUA, SV431DL2DU3A, SV431TDVIUA, SV831DVIU, USB2DVIE3, USB2DVIPRO2, USB32DVIEH, USB32DVIPRO, USB32HDDVII
