StarTech.com 3 ft DisplayPort to VGA Adapter Converter Cable – DP to VGA 1920x1200 - Black
Quicklinx: 907VWS00 Mfr#: DP2VGAMM3B
More than 50 in stock
£18.18 ex VAT
£21.81 inc VAT
Connect a DisplayPort-equipped PC to a nearby VGA monitor/Projector, with a short 3 foot cable. The DP2VGAMM3B active DisplayPort to VGA converter cable lets you connect your DisplayPort-equipped desktop or laptop directly to a nearby VGA monitor or projector, saving the expense of additional adapters while eliminating the clutter of excess cable.
Plus, because the converter cable supports video resolutions up to 1920x1200 you can convert a DisplayPort video source to VGA without sacrificing video quality.
StarTech.com DisplayPort to VGA Cable – 3ft / 91cm - 1920x1200 – Active DP to VGA Computer Monitor Adapter Cable (DP2VGAMM3B) - video converter - black
Video converter
Max Resolution
1920 x 1200
1 x DisplayPort input - 20 pin DisplayPort , 1 x VGA output - 15 pin HD D-Sub (HD-15)
4 cm 1.5 cm
Length
90 cm
Enclosure Colour
3-year warranty
Video converter
Max Resolution
1920 x 1200
1 x DisplayPort input - 20 pin DisplayPort - male , 1 x VGA output - 15 pin HD D-Sub (HD-15) - male
Active cable (signal regeneration)
1 - 90 cm
Plug and Play, FCC, RoHS
4 cm
1.5 cm
Length
90 cm
90 g
Enclosure Colour
Limited warranty - 3 years
60 °C
40 - 85%
907V StarTech.com 6 ft Mini DisplayPort to VGA Adapter Converter Cable – mDP to VGA 1920x1200 - Black In Stock £19.37
907V StarTech.com 3 ft Mini DisplayPort to VGA Adapter Converter Cable – mDP to VGA 1920x1200 - Black In Stock £18.18
907V StarTech.com 3 ft DisplayPort to VGA Adapter Converter Cable – DP to VGA 1920x1200 - Black In Stock £18.18
907V StarTech.com 6 ft DisplayPort to VGA Adapter Converter Cable – DP to VGA 1920x1200 - Black In Stock £19.37
907V StarTech.com 15 ft Mini DisplayPort to VGA Adapter Converter Cable – mDP to VGA 1920x1200 - Black In Stock £24.05
907V StarTech.com 10 ft Mini DisplayPort to VGA Adapter Converter Cable – mDP to VGA 1920x1200 - Black In Stock £23.56
907V StarTech.com 10 ft DisplayPort to VGA Adapter Converter Cable – DP to VGA 1920x1200 - Black In Stock £20.79
907V StarTech.com 15 ft DisplayPort to VGA Adapter Converter Cable – DP to VGA 1920x1200 - Black In Stock £26.46
Price Range Ex VAT: 0 - 50
