Connect a DisplayPort-equipped PC to a nearby VGA monitor/Projector, with a short 3 foot cable. The DP2VGAMM3B active DisplayPort to VGA converter cable lets you connect your DisplayPort-equipped desktop or laptop directly to a nearby VGA monitor or projector, saving the expense of additional adapters while eliminating the clutter of excess cable.
Plus, because the converter cable supports video resolutions up to 1920x1200 you can convert a DisplayPort video source to VGA without sacrificing video quality.
- StarTech.com 3ft DisplayPort to VGA Adapter Cable - 1920x1200 - Active DisplayPort (DP) Computer or Laptop to VGA Monitor or TV Display (DP2VGAMM3B) - video adapter cable - DisplayPort to HD-15 (VGA) - 1 m
- Video adapter cable
- Active cable, 2048 x 1280 support 60Hz, HBR2 support
- Length
- 1 m
- Connector
- 20 pin DisplayPort - male - latched
- Connector (Second End)
- 15 pin HD D-Sub (HD-15) - male
- DisplayPort 1.2
- Black
- 3-year warranty
- Length
- 1 m
- Black
- 79 g
- Connector
- DisplayPort 1.2, FCC, RoHS, EDID compatible
- Shipping Width
- 16 cm
- Shipping Depth
- 24 cm
- Shipping Height
- 2 cm
- Shipping Weight
- 90 g
- 3-year warranty
StarTech.com DisplayPort to VGA Video Adapter Converter | In Stock | £21.94 |
StarTech.com DisplayPort to VGA Video Adapter Converter | In Stock | £16.02 |
StarTech.com 6 ft Mini DisplayPort to VGA Adapter Converter Cable – mDP to VGA 1920x1200 - Black | In Stock | £19.44 |
StarTech.com 3 ft DisplayPort to VGA Adapter Converter Cable – DP to VGA 1920x1200 - Black | In Stock | £18.50 |
StarTech.com 6 ft DisplayPort to VGA Adapter Converter Cable – DP to VGA 1920x1200 - Black | In Stock | £20.73 |
StarTech.com 15 ft Mini DisplayPort to VGA Adapter Converter Cable – mDP to VGA 1920x1200 - Black | In Stock | £20.72 |
StarTech.com 10 ft DisplayPort to VGA Adapter Converter Cable – DP to VGA 1920x1200 - Black | In Stock | £21.05 |
StarTech.com 15 ft DisplayPort to VGA Adapter Converter Cable – DP to VGA 1920x1200 - Black | In Stock | £6.99 |
StarTech.com DisplayPort 1.2 to VGA Adapter Converter – DP to VGA – 1920x1200 | In Stock | £15.25 |
StarTech.com DP to VGA Adapter with Audio | In Stock | £6.80 |
StarTech.com DisplayPort to VGA Adapter - 1920x1200 | In Stock | £64.85 |
