StarTech.com 3 ft DisplayPort to VGA Adapter Converter Cable – DP to VGA 1920x1200 - Black
Quicklinx: 907VWS00 Mfr#: DP2VGAMM3B
£17.11 ex VAT
£20.53 inc VAT
Connect a DisplayPort-equipped PC to a nearby VGA monitor/Projector, with a short 3 foot cable. The DP2VGAMM3B active DisplayPort to VGA converter cable lets you connect your DisplayPort-equipped desktop or laptop directly to a nearby VGA monitor or projector, saving the expense of additional adapters while eliminating the clutter of excess cable.
Plus, because the converter cable supports video resolutions up to 1920x1200 you can convert a DisplayPort video source to VGA without sacrificing video quality.
  • High resolution support
    The cable supports a maximum output resolution of 2048 x 1280, ensuring sharp images across multiple displays.
  • Active cable technology
    Designed as an active cable, it boosts signal quality over longer distances, reducing the risk of image degradation.
  • Smooth refresh rate
    With a refresh rate of 60 Hz, this adapter cable delivers fluid motion and reduces lag during video playback or gaming.
  • Compliance and safety
    Adheres to FCC and RoHS standards for safe and reliable performance, ensuring compatibility with a range of devices.
  • Secure connection design
    Features latched connectors that provide a secure fit, maintaining a stable connection during use.
StarTech.com 3ft DisplayPort to VGA Adapter Cable - 1920x1200 - Active DisplayPort (DP) Computer or Laptop to VGA Monitor or TV Display (DP2VGAMM3B) - video adapter cable - DisplayPort to HD-15 (VGA) - 1 m
Video adapter cable
Active cable, 2048 x 1280 support 60Hz, HBR2 support
Length
1 m
Connector
20 pin DisplayPort - male - latched
Connector (Second End)
DisplayPort 1.2
3-year warranty
Video adapter cable
Length
1 m
79 g
Connector
DisplayPort 1.2, FCC, RoHS, EDID compatible
Shipping Width
16 cm
Shipping Depth
24 cm
Shipping Height
2 cm
Shipping Weight
90 g
3-year warranty
907V StarTech.com DisplayPort to VGA Video Adapter Converter In Stock £20.94
907V StarTech.com DisplayPort to VGA Video Adapter Converter In Stock £17.10
907V StarTech.com 6 ft Mini DisplayPort to VGA Adapter Converter Cable – mDP to VGA 1920x1200 - Black In Stock £17.93
907V StarTech.com 3 ft DisplayPort to VGA Adapter Converter Cable – DP to VGA 1920x1200 - Black In Stock £17.11
907V StarTech.com 6 ft DisplayPort to VGA Adapter Converter Cable – DP to VGA 1920x1200 - Black In Stock £19.06
907V StarTech.com 15 ft DisplayPort to VGA Adapter Converter Cable – DP to VGA 1920x1200 - Black In Stock £6.99
907V StarTech.com DisplayPort 1.2 to VGA Adapter Converter – DP to VGA – 1920x1200 In Stock £15.12
907V StarTech.com DP to VGA Adapter with Audio In Stock £6.80
907V StarTech.com DisplayPort to VGA Adapter - 1920x1200 In Stock £63.42
