StarTech.com 3 ft DisplayPort to DVI Active Adapter Converter Cable – DP to DVI 2560x1600 – Black
Quicklinx: 95PYWS00 Mfr#: DP2DVIMM3BS
Length: 91.5cm
More than 50 in stock
£23.16 ex VAT
£27.79 inc VAT
Eliminate excess cable clutter with a short 3ft DisplayPort to DVI active adapter. The DP2DVIMM3BS 3ft active DisplayPort to DVI converter cable lets you connect your DisplayPort-equipped desktop or laptop directly to a nearby DVI monitor or projector, saving the expense of additional adapters while eliminating the clutter of excess cable.
For guaranteed compatibility with virtually any DisplayPort output the active DisplayPort to DVI adapter supports multimode (DP++) as well as single-mode DisplayPort signals. Unlike passive adapters, this ensures the DP2DVIMM3BS can be used with graphics cards that are not capable of outputting multimode DP++ signals, such as ATI Eyefinity cards.
Plus, because the converter cable supports video resolutions up to 2560x1600 you can convert a DisplayPort video source to DVI without sacrificing video quality.
StarTech.com 3 ft DisplayPort to DVI Active Adapter Converter Cable - DisplayPort cable - 91.5 cm
DisplayPort cable
Active cable (signal regeneration)
Length
91.5 cm
Connector
DisplayPort - male
Connector (Second End)
DVI-D - male
FCC, RoHS
3-year warranty
StarTech.com Thunderbolt 3 Docking Station - USB-C (3.1 Gen 1&2) Adaptable
DisplayPort cable
Length
91.5 cm
Connector
20 pin DisplayPort - male
24+1 pin digital DVI - male
FCC, RoHS
3-year warranty
95PY StarTech.com 3 ft DisplayPort to DVI Active Adapter Converter Cable – DP to DVI 2560x1600 – Black In Stock £23.16
95PY StarTech.com 6 ft Mini DisplayPort to DVI Active Adapter Converter Cable - 2560x1600 – Black In Stock £27.00
95PY StarTech.com 6 ft Mini DisplayPort to DVI Active Adapter Converter Cable – 2560x1600 – White In Stock £28.80
95PY StarTech.com 3 ft Mini DisplayPort to DVI Active Adapter Converter Cable – DVI 2560x1600 – White In Stock £23.16
Length: 91.5cm
Price Range Ex VAT: 0 - 50
