StarTech.com 3 ft Cat 6a Blue Shielded Molded 10 Gigabit RJ45 STP Cat6a Patch Cable
Quicklinx: 7NWKWS00 Mfr#: C6ASPAT3BL
Length: 91cm
Colour: Blue
£6.47 ex VAT
£7.76 inc VAT
Make 10Gb Ethernet connections with PoE support. This high quality (blue) 3ft Cat 6a cable (STP) ensures dependable Ethernet connectivity, supporting 10 Gigabit performance up to 500 MHz - double that of standard Category 6 cable and five times the bandwidth offered by Cat5 - an excellent choice for Power over Ethernet (PoE) applications.
Plus, Cat 6a cables are backward-compatible with Cat5e and Cat6 cables, ensuring versatile network connection options.
All of Cat 6a cables are constructed of high quality 25 AWG shielded copper pairs to protect against noise and EMI/RFI interference, ensuring that Cat 6a cables are more than suitable for 10GBase-T Ethernet networks and Power over Ethernet applications.
StarTech.com Cat 6a patch cables provide end-to-end solutions that are tested for compliance with all TIA/ETL-568-B2.10 Category 6, UL 444 and ROHS 2002/95/EC specifications.
StarTech.com 3ft CAT6A Ethernet Cable, 10 Gigabit Shielded Snagless RJ45 100W PoE Patch Cord, CAT 6A 10GbE STP Network Cable w/Strain Relief, Blue, Fluke Tested/UL Certified Wiring/TIA - Category 6A - 26AWG (C6ASPAT3BL) - patch cable - 91 cm - blue
Patch cable - CAT 6a
Shielded twisted pair (STP)
Wiring Scheme
T568B
Shielding Material
Aluminium-polyester foil
Molded
Length
91 cm
Connector
RJ-45 - male
Connector (Second End)
RJ-45 - male
Blue
P/N: BNDTB10GI, ET10GSFP, ET91000SM10, ET91000SM20, SFP10GBTST, ST10000SPEXI, ST10GPEXNDPI, ST10GSPEXNB, ST20000SPEXI, ST5GPEXNB, SV565UTPDUV, SV565UTPHDU, TB310G
Network Cable Type
Wiring Scheme
T568B
Shielding Material
Jacket Material
PVC
American Wire Gauge (AWG)
26
Molded
Length
91 cm
Blue
Connector
RJ-45 - male
RJ-45 - male
UL 444, RoHS - up to 500 MHz
Length: 91cm
Colour: Blue
