The StarTech.com 3 ft. USB Cable is a high quality fully rated USB cable with the A-B Male-to-Male type connection. Typical applications for this cable are to connect from a PC or Mac to a USB peripheral like a printer, scanner, USB hub, etc. This cable is fully molded and manufactured to the USB V1.1 specifications.
- StarTech.com 3 ft Beige A to B USB 2.0 Cable - M/M - USB cable - USB (M) to USB Type B (M) - 3 ft - molded - USBFAB_3 - USB cable - USB to USB Type B - 0.9 m
- USB cable
- Molded
- Length
- 0.9 m
- Connector
- 4 pin USB Type A - male
- Connector (Second End)
- 4 pin USB Type B - male
- Limited lifetime warranty
- USB cable
- Molded
- Length
- 0.9 m
- Connector
