Extend the power connection from your server to a PDU by up to 3ft. The PXT100143 C13 to C14 PDU Style Computer Power Extension Cord (3ft) features 14 AWG wire suitable for high power connections, making it a reliable solution for large server applications that require a higher rated, heavier gauge cable, and connecting to Power Distribution Units (PDU).
This PDU style extension cord/cable is designed and constructed for maximum durability.
- StarTech.com 3 ft 14AWG Computer Power Cord Extension - C14 to C13 PDU Style Computer Power Extension Cable 14 AWG (PXT100143) - power extension cable - IEC 60320 C14 to IEC 60320 C13 - 90 cm
- Power extension cable
- Length
- 90 cm
- Connector
- Power IEC 60320 C14
- Connector (Second End)
- Power IEC 60320 C13
- Rated Voltage
- AC 250 V
- Black
- Limited lifetime warranty
- American Wire Gauge (AWG)
- 14
- Rated Voltage
- AC 250 V
- Length
- 90 cm
- Black
- Connector
- UL, RoHS
