StarTech.com 3 Bay Aluminum Trayless Hot Swap Mobile Rack Backplane for 3.5in SAS II/SATA III
Quicklinx: 98FZWS00 Mfr#: HSB3SATSASBA
Type: Storage mobile rack
HD Size: 2.5"
12 in stock
£64.25 ex VAT
£77.10 inc VAT
Easily connect and hot swap up to three 3.5" SATA/SAS hard drives from two 5.25" bays. The HSB3SATSASBA Removable 3-drive backplane lets you quickly install and hot-swap 3.5" drives from the front of your computer, by turning two 5.25" bays into a hot-swappable interface for you to connect up to three 3.5" SATA or SAS hard drives (HDD).
For added versatility, the hard drive bay can interface with SATA I/II/III and SAS I/II hard drives - an ideal accommodation for enterprise system applications.
For a quick and secure method of installing and removing drives, the backplane features ejection levers and a key-lock design. To help prevent drive failure, the bay provides excellent heat dissipation with a built-in fan, and a vented solid aluminum enclosure.
StarTech.com 3 Bay Trayless Hot Swap 3.5" SATA HDD Mobile Rack Backplane - storage mobile rack
Storage mobile rack
Expansion Bays
3 x hot-swap - 3.5"
Compatible Bay
2 5.25"
Hard Drive Form Factor Compatibility
2.5"
Supported Interface
SATA-600
Drive Connector
29 pin internal SAS (SFF-8482)
Data indicator, power indicator
Product Material
Aluminium
14.5 cm x 19.41 cm x 11 cm
1.2 kg
Storage mobile rack
2.5"
Product Material
Aluminium
Supported Interface
SATA-600
Bays
3 x hot-swap - 3.5"
3 x SATA 6Gb/s - 29 pin internal SAS (SFF-8482)
3 - 7 pin Serial ATA , 2 - 15 pin Serial ATA power
Compatible Bay
2 x external 5.25"
3 x Serial ATA cable - 45.72 cm
Mounting Kit
Included
FCC, RoHS
14.5 cm
19.41 cm
11 cm
1.2 kg
55 °C
5 - 85%
98FZ StarTech.com 12in Latching SATA Cable In Stock £3.33
98FZ StarTech.com 18in Latching SATA Cable In Stock £3.72
98FZ StarTech.com 24in Latching SATA Cable In Stock £4.46
98FZ StarTech.com 5.25in Trayless Hot Swap Mobile Rack for 3.5in Hard Drive In Stock £14.58
98FZ StarTech.com 2 Drive 2.5in Trayless Hot Swap SATA Mobile Rack Backplane In Stock £36.13
98FZ StarTech.com 8in Latching SATA to SATA Cable - F/F In Stock £3.41
98FZ StarTech.com 3 Bay Aluminum Trayless Hot Swap Mobile Rack Backplane for 3.5in SAS II/SATA III In Stock £64.25
HD Size: 2.5"
Price Range Ex VAT: 50 - 100
