Backup and Transfer Data at SuperSpeed USB 3.0 speeds. The SAT3510BU3 USB 3.0 External Hard Drive Enclosure lets you connect a 3.5in SATA hard drive through USB 3.0 - a cutting edge external storage solution that lets you harness the speed and performance supported by the SuperSpeed USB interface. Large capacity drives (tested with up to 4TB) can be used to greatly enhance your computer's storage/backup capabilities. Supporting data transfer rates of up to 5 Gbps, this external HDD enclosure delivers access to files at lightning fast speeds - 10x that of USB 2.0, and 60% faster than SATA II eSATA. Plus, the USB 3.0 interface is backward compatible with USB revisions 2.0 and 1.1, so the enclosure can be used with older systems that don't support the newest USB standard, at speeds of 480Mbps and 12 Mbps (respectively). The drive enclosure features a compact, free-standing design that requires minimal desk space, and is equipped with an 80mm fan that helps keep the installed hard drive cool for peak performance. This versatile external storage solution is compatible with a broad range of Windows operating systems, as well as Linux and Mac OS X and up.
- StarTech.com 3.5in USB 3.0 SATA External Hard Drive Enclosure w/ Fan - storage enclosure - SATA 6Gb/s - USB 3.0
- Storage enclosure - external
- Bus Type
- USB 3.0
- Expansion Bays
- 1 x internal - 3.5"
- Hard Drive Form Factor Compatibility
- 3.5"
- Interface
- SATA 6Gb/s
- Supported Devices
- Hard drive
- System Requirements
- Linux, Microsoft Windows Server 2008 R2, Apple MacOS X 10.4 - 10.6, Microsoft Windows Vista (32/64 bits), Microsoft Windows 7 (32/64 bits), Microsoft Windows XP (32/64 bits), Microsoft Windows Server 2003 (32/64-bits), Windows 8 (32/64 bits)
- 14.3 cm x 18 cm x 5.2 cm
- 580 g
- 2-year warranty
- Designed For
- P/N: PEXUSB3S23, PEXUSB3S24, PEXUSB3S25, PEXUSB3S42V, PEXUSB3S44V, PEXUSB3S4V, ST7300USBME, SVA12M2NEUA, SVA12M5NA, USB3SAB1, USB3SMDOCK4K
- 3.5"
- Host Bus
- USB 3.0
Storage Controller
- Interface
- SATA 6Gb/s
- Supported Devices
- Hard drive
- Processor
- ASMedia ASM1051
- Bays
- 1 x SATA 6Gb/s
- Connections
- 1 x USB 3.0
- Tested with up to 4TB 5400 RPM hard drives
- Plug and Play
- OS Required
- Limited warranty - 2 years
- 14.3 cm
- 18 cm
- 5.2 cm
- 580 g
- 0 °C
- 60 °C
- 10 - 90%
- Designed For
