StarTech.com 3.5in SATA to CompactFlash SSD Adapter Card for 3.5 Drive Bay
Quicklinx: 6BCTWS00 Mfr#: 35BAYCF2SAT
This 3.5in SATA to CompactFlash SSD Adapter Card allows you to connect a CompactFlash card to a host computer through a Serial ATA data port - a cost-effective solution that lets you use solid state storage in place of a SATA hard disk drive.
The adapter includes a 3.5in bracket that lets you mount it in the front or rear panel of the computer case, suitable for any 3.5in drive bay or available expansion slot - providing easy access to the CF slot. Once the adapter is installed in the computer, the CompactFlash card can be used as an ejectable, bootable drive - providing full read and write access to the CF card, as if it were a SATA hard drive.
StarTech.com 3.5in SATA to CompactFlash SSD Adapter Card for 3.5 Drive Bay - card reader - Serial ATA
Card reader - internal
Supported Memory Cards
CompactFlash Card type I, CompactFlash Card type II, Microdrive
Host Interface
Serial ATA
Required Bay
3.5" internal
1-year warranty
Host Interface
Serial ATA
Required Bay
3.5" internal
Memory Card
(max)
Required Ports
1 x 7 pin Serial ATA
3.5-inch bay adapter, rear expansion slot bracket
FCC, RoHS
Limited warranty - 1 year
