Brand
StarTech.com 3.5in Hard Drive to 5.25in Front Bay Bracket Adapter
Quicklinx: 4LV7WS00 Mfr#: BRACKETFDBK
Type: Bracket
More than 50 in stock
£5.17 ex VAT
£6.20 inc VAT
This plastic, floppy-drive adapter bracket lets you install a 3.5in floppy drive into a 5.25in bay. A simple solution that lets you position a 3.5in floppy drive in a computer case as needed (without being confined to the 3.5in floppy bay determined by the case layout), the floppy drive adapter bracket features an attractive open-faced black bezel that provides a snug, secured fit for installed drives.
StarTech.com 3.5" to 5.25" Front Bay Adapter - Mount 3.5" HDD in 5.25" Bay - Hard Drive Mounting Bracket w/ Mounting Screws (BRACKETFDBK) - storage bay adapter
Storage bay adapter
Expansion Bays
1 x front accessible - 3.5" x 1/3H
Compatible Bay
1 5.25" x 1/2H
Product Material
Metal
14.6 cm x 13.3 cm x 2.9 cm
P/N: 25SATSAS35HD, 35BAYCF2IDE, 35BAYUSB3S4, 35FCREADBK3, 35FCREADBU3, 35SAT225S3R, HSB220SAT25B, HSB225S3R, S251BU31REM, SAT2IDEADP, SATBP125VP, ST521PMINT
Storage bay adapter
Product Material
Metal
Storage Controller
No CPU
Bays
Compatible Bay
1 x external 5.25" x 1/2H
14.6 cm
13.3 cm
2.9 cm
4LV7 StarTech.com 3.5in Hard Drive to 5.25in Front Bay Bracket Adapter In Stock £5.17
4LV7 StarTech.com 3.5in Drive Bay IDE to Single CF SSD Adapter Card Reader In Stock £18.43
4LV7 StarTech.com SATA to 2.5in or 3.5in IDE Hard Drive Adapter for HDD Docks In Stock £19.33
4LV7 StarTech.com Dual 2.5" to 3.5" SATA Adapter In Stock £45.89
4LV7 StarTech.com 2.5" SATA Drive Hot Swap Bay In Stock £25.76
Type: Bracket
Stock Status: In stock
