This plastic, floppy-drive adapter bracket lets you install a 3.5in floppy drive into a 5.25in bay. A simple solution that lets you position a 3.5in floppy drive in a computer case as needed (without being confined to the 3.5in floppy bay determined by the case layout), the floppy drive adapter bracket features an attractive open-faced black bezel that provides a snug, secured fit for installed drives.
A Versatile Desktop Solution
The 3.5 to 5.25 front bay adapter provides a versatile solution that lets you install a 3.5" floppy drive, external facing USB hubs, media card readers, and fan controllers into the front bay of your PC computer, with ease. The adapter bracket features an attractive open-faced black bezel that provides a secure fit. The TAA compliant BRACKETFDBK is backed by a StarTech.com 2-year warranty and free lifetime technical support.
- StarTech.com 3.5" to 5.25" Front Bay Adapter - Mount 3.5" HDD in 5.25" Bay - Hard Drive Mounting Bracket w/ Mounting Screws (BRACKETFDBK) - storage bay adapter
- Storage bay adapter
- Black
- Expansion Bays
- 1 x front accessible - 3.5" x 1/3H
- Compatible Bay
- 1 5.25" x 1/2H
- Product Material
- Metal
- 14.6 cm x 13.3 cm x 2.9 cm
- 2-year warranty
- Designed For
- P/N: 25SATSAS35HD, 35BAYCF2IDE, 35BAYUSB3S4, 35FCREADBK3, 35FCREADBU3, 35SAT225S3R, HSB220SAT25B, HSB225S3R, S251BU31REM, SAT2IDEADP, SATBP125VP, ST521PMINT
- Product Material
- Metal
- Black
Storage Controller
- Processor
- No CPU
- Bays
- Compatible Bay
- 1 x external 5.25" x 1/2H
- Limited warranty - 2 years
- 14.6 cm
- 13.3 cm
- 2.9 cm
- Designed For
StarTech.com 3.5in Hard Drive to 5.25in Front Bay Bracket Adapter | In Stock | £5.88 |
StarTech.com 3.5in Drive Bay IDE to Single CF SSD Adapter Card Reader | In Stock | £19.38 |
StarTech.com SATA to 2.5in or 3.5in IDE Hard Drive Adapter for HDD Docks | In Stock | £22.89 |
StarTech.com 2.5in SATA/SAS SSD/HDD to 3.5in SATA Hard Drive Converter | In Stock | £15.89 |
StarTech.com 3.5in Front Bay 22-in-1 USB 2.0 Internal Multi Media Memory Card Reader - Black | In Stock | £13.15 |
StarTech.com 2.5" to 3.5" SATA Aluminium Hard Drive Adapter Enclosure SSD / HDD Height up to 12.5mm | In Stock | £23.87 |
StarTech.com 2.5 to 3.5 Hard Drive Adapter | In Stock | £24.24 |
