StarTech.com 3.5in 4 Drive eSATA USB FireWire External SATA RAID Enclosure
Quicklinx: 6LBLWS00 Mfr#: S354UFER
Turn 4 SATA hard drives into external RAID storage that connects over USB/FireWire/eSATA. StarTech.com's S354UFER External SATA RAID Enclosure is a high-performance external RAID storage solution, supporting up to 4 high capacity (tested with up to 4TB per bay) 3.5" SATA hard drives (supports SATA, SATA II and SATA III-6Gbps).
The 4-bay RAID enclosure can be connected to the host/source computer through USB, eSATA or FireWire and automatically builds your SATA RAID array based on your selection (Spanning, RAID 0, RAID 1, RAID 1+0, RAID 3, and RAID 5 supported), delivering a simple, yet flexible external storage solution.
Designed for convenience, the enclosure features front panel LED indicators that provide RAID information and simple hard drive status and activity monitoring. The enclosure also features a built-in 3-speed 80mm fan with automatic or manual controls that allow you to customize the speed of the fan as necessary, ensuring suitable operating temperatures for optimized drive performance.
StarTech.com 3.5in 4 Drive eSATA USB FireWire SATA RAID Enclosure - hard drive array
Hard drive array
Max Supported Capacity
16 TB
FireWire 800, USB 2.0, SATA 3Gb/s, FireWire 400
4 (max)
Supported Drives
SATA-300
Built-in Devices
Led panel
Storage Controller
RAID (SATA 3Gb/s) - RAID 0, 1, 3, 5, 10
Hard Drive
0 HDD SATA 3Gb/s - hot-swap
Linux, Microsoft Windows 2000, Apple MacOS X 10.4, Microsoft Windows Server 2008 R2, Apple MacOS X 10.6, Apple MacOS X 10.5, Microsoft Windows Vista (32/64 bits), Microsoft Windows 7 (32/64 bits), Microsoft Windows XP (32/64 bits), Microsoft Windows Server 2003 (32/64-bits), Apple MacOS X Lion 10.7, Apple OS X 10.8 Mountain Lion, Windows 8 (32/64 bits)
AC 120/230 V
12.6 cm x 21.5 cm x 17 cm
1.8 kg
1-year warranty
Hard drive array
Enclosure Colour
Chassis
Built-in Devices
Led panel
Supported Devices / Modules Qty
4
Supported Drives
SATA-300
Storage
16 TB
HDD Array External Interface
Storage Controller
RAID
Channel Qty
4
Interface Type
SATA 3Gb/s
Data Transfer Rate
300 MBps
Supported Devices
Hard drive, disk array (RAID)
RAID Level
RAID 0, RAID 1, RAID 3, RAID 5, RAID 10
Hard Drive
HDD - hot-swap
0
Interface Type
SATA 3Gb/s
Expansion Bays
4 (total) / 4 (free) x hot-swap - 3.5"
1 x eSATA 3Gb/s - 7 pin external Serial ATA , 1 x USB 2.0 - 4 pin USB Type B , 1 x FireWire - 6 PIN FireWire , 1 x FireWire 800 - 9 pin FireWire 800
1 x eSATA cable , 1 x USB cable , 1 x IEEE 1394 cable , 1 x IEEE 1394b cable
FCC, RoHS
External power adapter
AC 120/230 V
12.6 cm
21.5 cm
17 cm
1.8 kg
Limited warranty - 1 year
-20 °C
60 °C
