StarTech.com 3.5 Right Angle Stereo Cable
Quicklinx: 7B5XWS00 Mfr#: MU1MMSRA
Length: 30cm
£4.27 ex VAT
£5.12 inc VAT
Easily connect an iPod or other MP3 player to a car stereo.
This 1-foot stereo audio cable features one right angle stereo audio connector and one 3.5mm (straight) connector with a slim connector molding that makes this the perfect solution for portable audio devices (iPod, iPhone, iPad, MP3 Players), even if the device is in a protective case.
For those difficult to reach areas, the 3.5mm stereo audio to 3.5mm right angle cable allows you to connect where a normal straight stereo audio connector cannot.
StarTech.com 1 ft. (0.3 m) Right Angle 3.5 mm Audio Cable - 3.5mm Slim Audio Cable - Right Angle - Male/Male - Aux Cable (MU1MMSRA) - audio cable - 30 cm
Cable
Audio cable
American Wire Gauge (AWG)
30
Length
30 cm
Connector
Mini-phone stereo 3.5 mm - male
Connector (Second End)
Right-angled connector
P/N: SV231DVGAU2A, SV431DVGAU2A
Cable Type
Audio cable right-angled connector
30
Jacket Material
PVC
Length
30 cm
Plated Connector
Gold
Moulded
Connector
RoHS
Limited warranty - lifetime
7B5X StarTech.com 1 ft Slim 3.5mm Stereo Audio Cable - M/M In Stock £4.57
7B5X StarTech.com 10 ft Slim 3.5mm Stereo Audio Cable - M/M In Stock £4.99
7B5X StarTech.com 15 ft Slim 3.5mm Stereo Audio Cable - M/M In Stock £5.83
7B5X StarTech.com 1 ft Slim 3.5mm Right Angle Stereo Audio Cable - M/M In Stock £3.00
7B5X StarTech.com 3.5 Right Angle Stereo Cable In Stock £4.27
7B5X StarTech.com 3 ft Slim 3.5mm Stereo Audio Cable - M/M In Stock £3.11
7B5X StarTech.com 6 ft Slim 3.5mm Stereo Audio Cable - M/M In Stock £3.79
7B5X StarTech.com 2m 3.5mm 4 Position TRRS Headset Extension Cable - M/F In Stock £5.91
Length: 30cm
