StarTech.com 3.5 mm to 3.5 mm Audio Coupler - Female to Female
Quicklinx: 76MJWS00 Mfr#: GCAUD3535FF
£5.47 ex VAT
£6.56 inc VAT
The GCAUD3535FF Audio Cable Adapter/Audio Coupler features two 3.5mm audio female connectors, providing a cost-effective way to combine two standard 3.5mm stereo headphone cables or convert a standard audio cable into an extension cable.
  • Gold plated connectivity
    The 3.5mm Female to Female Coupler features gold plated connectors, ensuring a high-quality connection that maintains the purity of the audio signal for clear, uninterrupted sound.
  • Versatile audio coupling
    Designed to extend the reach of your existing audio cable, this coupler seamlessly connects two male 3.5mm audio cables together, making it ideal for a wide range of audio applications.
  • Durable design
    Constructed with a PVC jacket material, the coupler is built to withstand regular use while ensuring flexibility and protection for the internal connectors, offering both durability and reliability.
StarTech.com 3.5mm Female to Female Coupler - 3.5mm Audio Coupler - Gold Plated Connectors - Female/Female - Aux Cord Adapter (GCAUD3535FF) - audio coupler
Cable
Audio coupler
Connector
Mini-phone stereo 3.5 mm - female
Connector (Second End)
P/N: MU15MMS, MU6MMS, SV231QDVIUA, SV231TDVIUA, SV431DL2DU3A, SV431TDVIUA
Cable Type
Audio coupler
Jacket Material
PVC
Plated Connector
Gold
Connector
RoHS
Limited warranty - lifetime
76MJ StarTech.com 6 ft 3.5mm Stereo Extension Audio Cable - M/F In Stock £4.89
76MJ StarTech.com 12 ft PC Speaker Extension Audio Cable In Stock £5.37
76MJ StarTech.com 6in Stereo Audio Cable - 3.5mm Male to 2x RCA Female In Stock £4.25
