The GCAUD3535FF Audio Cable Adapter/Audio Coupler features two 3.5mm audio female connectors, providing a cost-effective way to combine two standard 3.5mm stereo headphone cables or convert a standard audio cable into an extension cable.
Gold plated connectivity
The 3.5mm Female to Female Coupler features gold plated connectors, ensuring a high-quality connection that maintains the purity of the audio signal for clear, uninterrupted sound. -
Versatile audio coupling
Designed to extend the reach of your existing audio cable, this coupler seamlessly connects two male 3.5mm audio cables together, making it ideal for a wide range of audio applications. -
Durable design
Constructed with a PVC jacket material, the coupler is built to withstand regular use while ensuring flexibility and protection for the internal connectors, offering both durability and reliability.
- StarTech.com 3.5mm Female to Female Coupler - 3.5mm Audio Coupler - Gold Plated Connectors - Female/Female - Aux Cord Adapter (GCAUD3535FF) - audio coupler
- Cable
- Audio coupler
- Black
- Connector
- Mini-phone stereo 3.5 mm - female
- Connector (Second End)
- Limited lifetime warranty
- Designed For
- P/N: MU15MMS, MU6MMS, SV231QDVIUA, SV231TDVIUA, SV431DL2DU3A, SV431TDVIUA
- Cable Type
- Audio coupler
- Jacket Material
- PVC
- Plated Connector
- Gold
- Black
- Connector
- RoHS
- Limited warranty - lifetime
- Designed For
StarTech.com 6 ft 3.5mm Stereo Audio Cable - M/M | In Stock | £4.64 |
StarTech.com 6 ft 3.5mm Stereo Extension Audio Cable - M/F | In Stock | £4.82 |
StarTech.com 12 ft PC Speaker Extension Audio Cable | In Stock | £5.33 |
StarTech.com 6in Stereo Audio Cable - 3.5mm Male to 2x RCA Female | In Stock | £4.20 |
