StarTech.com 3.5" SATA enclosure
Quicklinx: DBCVWS00 Mfr#: S351BMU33ETG
The hard drive enclosure enables you to swap drives in and out as needed, with the trayless design. The enclosure is simple to set up and easy to use, with its Plug-and-Play functionality. It's is also equipped with an LED light to indicate power and activity.
  • Multiple connectivity options
    The external hard drive enclosure supports USB 3.0, also known as USB 3.1 Gen 1, and eSATA, which enables you to access your data through your preferred interface. For fast performance and efficient data transfers, when connected through eSATA, the enclosure supports full SATA III transfer speeds - up to 6Gbps.
  • Ease of use
    The hard drive enclosure enables you to swap drives in and out as needed, with the trayless design. The enclosure is simple to set up and easy to use, with its plug-and-play functionality. It's is also equipped with an LED light to indicate power and activity.
StarTech.com 3.5" SATA Hard Drive Enclosure - eSATA / USB 3.0 - Trayless - storage enclosure - SATA 6Gb/s - eSATA, USB 3.0
Storage enclosure - external
Bus Type
eSATA, USB 3.0
Expansion Bays
1 x hot-swap - 3.5"
Hard Drive Form Factor Compatibility
3.5"
SATA 6Gb/s
Data Transfer Rate
6 Gbit/s
Supported Devices
Hard drive
Product Material
Metal
Power Source
Included AC adapter
AC 120/230 V / DC 12 V
3.5"
Host Bus
eSATA, USB 3.0
Product Material
Metal
Storage Controller
SATA 6Gb/s
Data Transfer Rate
6 Gbit/s
Supported Devices
Hard drive
ASM1153E / ASM1456
Bays
1 x hot-swap - 3.5"
SATA 6Gb/s
1 x USB 3.0 , 1 - 7 pin external Serial ATA
Stand
1 x eSATA cable , 1 x USB cable
UASP transfer protocol, S.M.A.R.T. support, TRIM support, trayless design
FCC, RoHS, RCM
Power Source
Included AC adapter
Power adapter
24 Watt
50 °C
5 - 65%
DBCV StarTech.com 6 ft Shielded External eSATA Cable M/M In Stock £9.58
DBCV StarTech.com 2.5in SATA/SAS SSD/HDD to 3.5in SATA Hard Drive Converter In Stock £13.55
DBCV StarTech.com 1m USB 3 Cable Right Angle BK In Stock £7.23
DBCV StarTech.com 2m (6 ft) Certified SuperSpeed USB 3.0 A to B Cable - M/M In Stock £9.84
DBCV StarTech.com 1m (3ft) Certified SuperSpeed USB 3.0 A to B Cable - M/M In Stock £7.61
DBCV StarTech.com USB 3.1 Gen 2 Single-bay Dock In Stock £53.68
DBCV StarTech.com USB 3.1 / eSATA 1-bay Dock In Stock £54.05
DBCV StarTech.com DC Power Adapter - 12V, 2A In Stock £11.76
DBCV StarTech.com DC Power Adapter - 12V, 5A In Stock £42.05
