StarTech.com 3.5" Bay USB Card Reader
Quicklinx: 7NVWWS00 Mfr#: 35FCREADBK2
This 3.5-inch front bay mount 22-in-1 multimedia card reader allows for quick and easy access to the most popular flash card formats, from almost any desktop computer with a 3.5-inch bay opening.
With support for Compact Flash (CF type I/II), Secure Digital (SD/miniSD/microSD/SDHC/SDXC), MultiMediaCard (MMC/RS-MMC/HS-MMC/MMCmobile/MMCplus/MMCmicro/HC-MMC), MemoryStick (MS/MS Duo/HS-MS/MS PRO/MS PRO Duo/MS PRO-HG Duo/MS-ROM/M2), and xD Picture cards, this reader is ready to handle the memory cards from virtually any portable device from cameras to music players.
Please note these do not support SmartMedia (SM)
StarTech.com 3.5in Front Bay 22-in-1 USB 2.0 Multi Media Memory Card Reader - card reader - USB 2.0
Card reader
Supported Memory Cards
CompactFlash Card type I, CompactFlash Card type II, Memory Stick, MultiMediaCard, SD Memory Card, miniSD, microSD, SDHC Memory Card, SDXC Memory Card
Host Interface
USB 2.0
Required Bay
3.5" internal
Card reader
Host Interface
USB 2.0
Required Bay
3.5" internal
10 cm
13 cm
2.5 cm
180 g
Memory Card
(max)
Microsoft Windows 2000, Microsoft Windows Server 2008 R2, Linux 2.4.x or later, Microsoft Windows Vista (32/64 bits), Microsoft Windows 7 (32/64 bits), Microsoft Windows XP (32/64 bits), Microsoft Windows Server 2003 (32/64-bits), Windows 8 (32/64 bits)
FCC, RoHS
