The StarTech.com 3.3 ft USB Multi Charging Cable is a versatile and durable solution for all your charging needs. With the ability to connect to Lightning, Micro-USB, and Type-C devices, this cable is perfect for anyone who uses multiple types of electronics. It's designed to withstand the rigors of daily use, featuring a 30,000 bend lifespan, aramid-reinforced core, and wear-resistant materials. The cable supports up to 15 W of power delivery, ensuring your devices charge efficiently. Additionally, with a 480 Mbps data rate, you can sync your devices at high speeds, making this cable a great choice for both charging and data transfer needs. Whether at home, in the office, or on-the-go, this USB cable kit from StarTech.com offers the reliability and performance you need.
Versatile connectivity
This 3.3 ft USB Multi Charging Cable is a reliable solution for charging a wide range of devices. With Lightning, Micro-USB, and Type-C connectors, it ensures compatibility with an extensive array of smartphones, tablets, and other electronic devices, making it an essential accessory for modern digital lifestyles. -
Durable design
Engineered for longevity, the cable features an aramid-reinforced core, wear-resistant materials, and a 30,000 bend lifespan. Its rugged construction, combined with copper conductors and shielded technology, provides both durability and reliable performance for syncing and charging tasks. -
High-speed performance
Achieve efficient syncing and charging with up to 15 W of power delivery and a 480 Mbps data rate. The cable's design ensures a fast and stable connection, allowing you to power up your devices quickly and transfer data seamlessly.
- StarTech.com 3.3ft USB Multi Charging Cable, Lightning/Micro-USB/Type-C - USB cable kit - 1 m
- USB cable kit
- Technology
- Shielded
- Rugged, passive cable, wear-resistant, 30000 bend lifespan, sync and charge, 480 Mbps data rate, up to 15 Watts of power delivery, copper conductors, aramid-reinforced core
- Length
- 1 m
- Rated Current
- 3 A
- USB / USB 2.0
- Black
- 2-year warranty
- USB cable kit
- Technology
- Shielded
- Shielding Material
- Aluminum mylar foil with braid
- Jacket Material
- Thermoplastic elastomer (TPE)
- Rated Current
- 3 A
- Plated Connector
- Nickel
- Length
- 1 m
- Outside Diameter
- 5.6 mm
- Black
- 41 g
- Cable Kit Details
- 1 x USB cable - 4 pin USB Type A (male) to 5 pin Micro-USB Type B (male) - 1 m , 1 x Lightning adapter - 5 pin Micro-USB Type B (female) to Apple Lightning connector (male) , 1 x USB-C adapter - 5 pin Micro-USB Type B (female) to 24 pin USB-C (male)
- USB / USB 2.0, MFI, WEEE, RoHS
- Shipping Width
- 22 cm
- Shipping Depth
- 12.8 cm
- Shipping Height
- 2 cm
- Shipping Weight
- 65 g
- 2-year warranty
